[Mapserver-users] Using MapServer as a general graphing engine
Daniel Morissette
morissette at dmsolutions.ca
Mon Jul 28 15:16:17 EDT 2003
Armin Burger wrote:
> I also found it sometimes desirable to have Mapserver create thematical
> maps with pie charts or bar charts, etc. I don't know how much work it
> might be to implement this. Maybe DM Solutions OWTChart could be somehow
> included?
Creating an (optional) extension for MapServer using GDChart (the engine
behind OWTChart) would be technically possible.
However most of the work would be to define what we want to do with
charts and how they interact with the map, which mapfile parameters are
required to control them, etc. If you guys could come up with some kind
of requirements/specifications with examples of what you want to see
then that could help selling the idea for a future release.
> Another, probably a bit easier implementation, could be using MapScript
> combined with graphic modules/extensions for Perl or PHP, mainly based on
> the GD library. But as far as I know there is no possibility to include
> externally produced images and merge them on top of the map image. A
> question to the developers: would it be possible to have a Mapscript
> method that creates an imageObj from a file?
You could do the reverse: save your map image and load it using the PHP
GD extension and use the PHP GD extension to paste the charts on top of
the map.
As you wrote already, this would work fine only for a small number of
charts. As the number of charts to draw on the map increases, the
overhead of external calls to create charts and save them to temporary
images could become significant.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
