[Mapserver-users] compilation of ms40 crashes
Norbert Schauerte-Lueke
nsl at regio-gis-planung.de
Thu Jul 31 11:14:56 EDT 2003
I try to compile mapserver 40 beta2 on an Suse 8.2 with wms support. The compilations
crashes at mapcontext.c. Starting the compilation of mapcontext.c the following
warnings and errors are written out:
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ -
DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_TIFF -
DUSE_JPEG -DUSE_
GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_PDF -
I/usr/local/include -I/usr/local/include mapcontext.c -o mapc
ontext.o
mapcontext.c:181:25: cpl_minixml.h: Datei oder Verzeichnis nicht gefunden
mapcontext.c:247: error: parse error before '*' token
mapcontext.c: In function `msGetMapContextXMLHashValue':
mapcontext.c:252: warning: implicit declaration of function `CPLGetXMLValue'
mapcontext.c:252: error: `psRoot' undeclared (first use in this function)
mapcontext.c:252: error: (Each undeclared identifier is reported only once
mapcontext.c:252: error: for each function it appears in.)
mapcontext.c:252: error: `pszXMLPath' undeclared (first use in this function)
mapcontext.c:255: error: `metadata' undeclared (first use in this function)
mapcontext.c:257: error: `pszMetadata' undeclared (first use in this function)
mapcontext.c: At top level:
mapcontext.c:278: error: parse error before '*' token
mapcontext.c: In function `msGetMapContextXMLHashValueDecode':
mapcontext.c:285: error: `psRoot' undeclared (first use in this function)
mapcontext.c:285: error: `pszXMLPath' undeclared (first use in this function)
mapcontext.c:288: error: `metadata' undeclared (first use in this function)
mapcontext.c:291: error: `pszMetadata' undeclared (first use in this function)
mapcontext.c:313: error: parse error before '*' token
mapcontext.c: In function `msGetMapContextXMLStringValue':
mapcontext.c:318: error: `psRoot' undeclared (first use in this function)
mapcontext.c:318: error: `pszXMLPath' undeclared (first use in this function)
mapcontext.c:321: error: `pszField' undeclared (first use in this function)
mapcontext.c:345: error: parse error before '*' token
mapcontext.c: In function `msGetMapContextXMLStringValueDecode':
mapcontext.c:350: error: `psRoot' undeclared (first use in this function)
mapcontext.c:350: error: `pszXMLPath' undeclared (first use in this function)
mapcontext.c:353: error: `pszField' undeclared (first use in this function)
mapcontext.c:378: error: parse error before '*' token
mapcontext.c: In function `msGetMapContextXMLFloatValue':
mapcontext.c:383: error: `psRoot' undeclared (first use in this function)
mapcontext.c:383: error: `pszXMLPath' undeclared (first use in this function)
mapcontext.c:386: error: `pszField' undeclared (first use in this function)
mapcontext.c:410: error: parse error before '*' token
mapcontext.c: In function `msCombineXMLValueInHash':
mapcontext.c:418: error: `psRoot' undeclared (first use in this function)
mapcontext.c:418: error: `pszXMLPath1' undeclared (first use in this function)
mapcontext.c:419: error: `pszXMLPath2' undeclared (first use in this function)
mapcontext.c:420: error: `pszXMLPath3' undeclared (first use in this function)
mapcontext.c:421: error: `pszXMLPath4' undeclared (first use in this function)
mapcontext.c:426: error: `metadata' undeclared (first use in this function)
mapcontext.c:436: error: `pszMetadata' undeclared (first use in this function)
mapcontext.c: In function `msLoadMapContext':
mapcontext.c:467: error: `CPLXMLNode' undeclared (first use in this function)
mapcontext.c:467: error: `psRoot' undeclared (first use in this function)
mapcontext.c:467: error: `psContactInfo' undeclared (first use in this function)
mapcontext.c:467: error: `psMapContext' undeclared (first use in this function)
mapcontext.c:467: error: `psLayer' undeclared (first use in this function)
mapcontext.c:467: error: `psLayerList' undeclared (first use in this function)
mapcontext.c:467: warning: left-hand operand of comma expression has no effect
mapcontext.c:468: error: `psFormatList' undeclared (first use in this function)
mapcontext.c:468: error: `psFormat' undeclared (first use in this function)
mapcontext.c:468: error: `psStyleList' undeclared (first use in this function)
mapcontext.c:468: error: `psStyle' undeclared (first use in this function)
mapcontext.c:468: error: `psChild' undeclared (first use in this function)
mapcontext.c:468: error: `psKeyword' undeclared (first use in this function)
mapcontext.c:469: error: `psKeywordList' undeclared (first use in this function)
mapcontext.c:469: warning: left-hand operand of comma expression has no effect
mapcontext.c:470: error: `psLegendURL' undeclared (first use in this function)
mapcontext.c:470: error: `psSRS' undeclared (first use in this function)
mapcontext.c:470: warning: left-hand operand of comma expression has no effect
mapcontext.c:500: warning: implicit declaration of function `CPLParseXMLString'
mapcontext.c:516: error: `CXT_Element' undeclared (first use in this function)
mapcontext.c:517: warning: implicit declaration of function `EQUAL'
mapcontext.c:531: warning: implicit declaration of function `CPLDestroyXMLNode'
mapcontext.c:595: warning: comparison between signed and unsigned
mapcontext.c:678: warning: implicit declaration of function `CPLGetXMLNode'
mapcontext.c:1170: error: `CXT_Text' undeclared (first use in this function)
make: *** [mapcontext.o] Fehler 1
The configure options are:
--with-proj --with-wmsclient
The libs are:
curl-7.10.5
proj-4.4.7
gd-2.0.15
freetype-2.1.2
libpng-1.2.3
pdflib-4.0.3
Linux is installed without X-server
Thanks in advance
nsl
