[Mapserver-users] Image not visible
Attri, Abhishek
aattri at cba.ua.edu
Thu Jul 31 14:32:16 EDT 2003
Yes, the problem was with the extent. Thanks a lot. Please let me know
where can I find the shpinfo.pl script?
With thanks
Abhishek
-----Original Message-----
Sent: Thursday, July 31, 2003 7:51 AM
To: Attri, Abhishek
Subject: Re: [Mapserver-users] Image not visible
Most likely you need to set a new EXTENT in your map file which matches
the extent of you shapefile. Run the shpinfo.pl -file=myfile.shp to see
what extents it reports and try using those in your map file.
On Thu, 2003-07-31 at 15:02, Attri, Abhishek wrote:
> Hi!
> I started using PHP MapScript and was able to successfully
> run the demo examples in "PHP MapScript 3.5 by Example HOWTO". But
when
> I substituted the shape files with some different shape files and
tried
> to display them, I see nothing on the web page. I checked my /tmp
> image being created and stored , but nothing is visible on screen. Can
> somebody help me with that?
> With thanks
> Abhishek
