[Mapserver-users] Image not visible
Fawcett, David
David.Fawcett at state.mn.us
Thu Jul 31 11:52:11 EDT 2003
No problem, good luck with MapServer.
> From: Attri, Abhishek[SMTP:aattri at cba.ua.edu]
> Sent: Thursday, July 31, 2003 10:50 AM
> To: Fawcett, David
> Subject: RE: [Mapserver-users] Image not visible
> Yes, you were right. Thanks a lot!
> Abhishek
> -----Original Message-----
> From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
> Sent: Thursday, July 31, 2003 10:12 AM
> To: Attri, Abhishek
> My guess is that the shapefiles that you swapped in do not contain
> features located in Itasca County, Minnesota, and therefore don't fall
> within the extent specified in the mapfile.
> If you haven't done so, you will have to determine new extents for the
> shapes that you wish to display and edit your map file.
> David.
> > Sent: Thursday, July 31, 2003 10:02 AM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] Image not visible
> > Hi!
> > I started using PHP MapScript and was able to successfully
> run the demo examples in "PHP MapScript 3.5 by Example HOWTO". But when
> I substituted the shape files with some different shape files and tried
> to display them, I see nothing on the web page. I checked my /tmp
> image being created and stored , but nothing is visible on screen. Can
> somebody help me with that?
> > With thanks
> > Abhishek
