[Mapserver-users] MapServer on Windows XP and IIS
Ed McNierney ed at topozone.com
Thu Jul 31 10:19:42 PDT 2003
Jeff -
I would not claim Apache is "easier" than IIS in this regard.  In general, I don't think either of them (we run both) is hard or easy - they're just different, and you need to understand something about running Web servers and running CGI services on Web servers in order to run MapServer.  Both IIS and Apache have a security model that lets you control which files are available to which Web users, and what those users can do to those files (run them, read them, write to them, etc.).
Read the help on IIS - that's what it's for.  If you did a default install/config you installed all the administration help files, and they're pretty reasonable.
I'm not trying to be unhelpful, but if you don't understand the security model and how it applies to Web services, you're going to keep bumping into one problem after another.  Take the time to understand how to set up your Web server, and THEN you'll be ready to set up MapServer.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Thursday, July 31, 2003 1:15 PM
To: Ed McNierney; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] MapServer on Windows XP and IIS
Ed,
I'm new to web configuration. All i did is installing IIS on my windows XP
pro and then installed MapServ.
I guess that the web server is not configured, i have no idea how to do it.
Any info is appreciated.
I heard that Apache would work easier than IIS. Apache would need specific
configuration or just a sandard installation ?
Thanks
Jeff Lacoste
>From: "Ed McNierney" <ed at topozone.com>
>To: "Jeff L." <nf10 at hotmail.com>,<mapserver-users at lists.gis.umn.edu>
>Date: Thu, 31 Jul 2003 12:47:16 -0400
>Jeff -
>If your Web server is configured correctly, there will be NO command window
>opening and closing.  You'll get that error text in a regular Web page that
>stays there.
>I suspect that the directory in which mapserv.exe is installed does not let
>users execute programs (like CGI programs) from it.
>	- Ed
>From: Jeff L. [mailto:nf10 at hotmail.com]
>Sent: Thursday, July 31, 2003 10:27 AM
>Thanks Ed for your relpy.  MapServ is installed in the IIS of my windows XP
>machine. While trying to run it (localy from web browser pointing the
>"mapser.exe", the command window is opened then closed pretty fast. I have
>no idea about the content of the command window. I'm not sure what message
>was displayed there. At least if i know that was "No query information to
>decode. QUERY_STRING not set." It can get me going to the next steps
>(running the demo).
>Thanks again
>Jeff Lacoste
> >Date: Thu, 31 Jul 2003 09:44:10 -0400
> >Jeff -
> >There's no problem - that's the way it's supposed to work!
> >You can run MapServer from the command line with the "-v" switch, and
> >you'll get text output.  Normally CGI programs are not meant to be run
>from
> >the command line, and MapServer is no exception.
> >If you properly configure your Web site to allow users to execute CGI
> >programs, you should be able to type the following in your browser:
> >http://server.yourdomain.com/mapserv
> >(replace the server and domain names with your names)
> >and get the error message:
> >"No query information to decode. QUERY_STRING not set."
> >in your browser window.
> >Until you get to that point, you haven't managed to get a basic CGI
>program
> >running, so there's no point in doing anything else yet!
> >	- Ed
> >Ed McNierney
> >ed at topozone.com
> >(978) 251-4242
> >Sent: Thursday, July 31, 2003 7:29 AM
> >To: mapserver-users at lists.gis.umn.edu
> >Subject: [Mapserver-users] MapServer on Windows XP and IIS
> >Hi,
> >I installed MapServer on Windows XO and IIS. When i try to execute the
> >mapserv from the command window (C:\Inetpub\Scripts\MapServ), i have an
> >error: "This script can only be used to decode form results and should be
> >initiated as a CGI process via a httpd server ". I tried also to execute
> >the
> >script from Internet Explorer. The result is a command window displayed
> >then
> >closed fast.
> >Any idea about the possible problem ?
> >Thanks,
> >Jeff Lacoste
> >_________________________________________________________________
> >The new MSN 8: advanced junk mail protection and 2 months FREE*
> >http://join.msn.com/?page=features/junkmail
> >Mapserver-users mailing list
> >Mapserver-users at lists.gis.umn.edu
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>Add photos to your messages with MSN 8. Get 2 months FREE*.
>http://join.msn.com/?page=features/featuredemail
The new MSN 8: smart spam protection and 2 months FREE*
More information about the MapServer-users mailing list
