[Mapserver-users] python styleObj classObj colorObj question in 4.x
Heitzso
heitzso at growthmodels.com
Thu Jul 31 12:42:24 PDT 2003
(I'm working with cvs mapserver_dev from a couple
weeks ago. Let me know please if that's my problem.)
Trying to create a layer to display in python mapscript.
I have the code working great with existing layers from
the map file. But failing to draw layers created in
code. The map will draw (when I don't have the code
buggered with experiments) but nothing shows. I assumed
I don't have the outline color set correctly. The layer
I'm building up is based on a layer that works when
accessed from the mapfile. Code snippet ...
map = mapObj(mapFilename)
img = map.prepareImage()
layer = layerObj(map)
layer.name = 'test'
layer.connection = "a postgis conn that works in mapfile"
layer.connectiontype = MS_POSTGIS
layer.data = "the_geom from counties"
layer.status = MS_ON
layer.type = MS_LAYER_POLYGON
c = classObj(layer)
c.name = "testclass"
style = styleObj(c) <-- CRASH!!!!!!!!!
style.outlinecolor = setRGB(0,0,0)
c.status = MS_ON
layer.draw(map, img)
map.drawLabelCache(img)
img.save(imagePath + imageFilename)
I find doc confusing, cross ups between 3.x and 4.x
version and perl/php/python variations in code style
and doc version.
For instance ...
doc states styleObj constructed with classObj
passed in, i.e. 's = styleObj(cObj)' but
mapscript complains that method must not have
an argument ?!
doc also states that everything migrated over
to styleObj but it's not clear if that's
_required_ or suggested
Could someone enlighten me?
THANKS!
Heitzso
More information about the MapServer-users
