[Mapserver-users] Mapfile format in XML
Antti.Roppola at brs.gov.au
Mon Jun 2 01:16:12 EDT 2003
Hi all,
I have added an entry to the FAQ on the Wiki, but was not able to find
the post I was looking for that explained the pros and cons nicely.
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?FAQ
If anyone wants to improve on my rather vague entry, feel free to do so.
Cheers,
Antti
-----Original Message-----
Sent: Monday, 2 June 2003 6:11 AM
To: spencer at dmsolutions.ca; Paul Spencer
Cc: Morten Nielsen; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Mapfile format in XML
Hear, hear.
XML may be the future, but it isn't the answer to every task.
And validating a line oriented format like the MAP file shouldn't be too
difficult. Maybe someone has made a validator for it already ?
Best regards / Med venlig hilsen
Lars V. Nielsen
Hvenegaard & Meklenborg, Odense
http://www.hvm.dk
Citering Paul Spencer <pagameba at magma.ca>:
> No, although this has been discussed extensively. If you search the
> list archives I believe that for the near term the decision was that XML
> would likely add too much overhead (especially if it validates) to the
> parsing process (and probably adds an additional library dependency on
> something like xerces) and no real benefits. The MapServer developers
> place a high emphasis on keeping the core of MapServer lean and mean so
> it can perform very well in high-load situations, so I believe that it
> is unlikely that a compelling argument for XML could be made that would
> influence the core developers.
> If you really believe strongly in it, though, you can do it yourself and
> then try to sell the idea (ah, the beauty of open source ;)).
> The capability that Gerald refers to is an XML format for a
> "map-file-like" document that describes WMS layers only, and does not
> directly include the ability to style layers, add labels, and all the
> other cool things that MapServer can do via the MAP file. MapServer
> support for Contexts requires the GDAL library and parses the XML using
> the GDAL minixml driver, which is a non-validating parser. This format
> is probably of very little actual benefit to most MapServer users except
> those that use WMS. The Context document itself is meant primarily as
> an interchange format that allows users to share views.
> Cheers,
> Paul
> Gerald Buckmaster wrote:
> > Hi,
> > I think this link might be what you are looking for:
> > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapContextHowto
> > HTH
> > Gerald
> Morten Nielsen wrote:
> > Is there any plans on upgrading/supplementing the MAP format to XML ?
> > It would make a lot of things easier, when processing the Map file in
> other
> > scripts (not to mention the validating that a DTD could offer).
> > XML is the future :-)
> > /Morten Nielsen
> > http://www.iter.dk
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Paul Spencer
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
