[Mapserver-users] perl mapscript 3.6.5
Thorsten Fischer
thfischer at mapmedia.de
Wed Jun 4 05:08:22 EDT 2003
On Wed, 2003-06-04 at 00:46, mapsurfer wrote:
> My setup is a freebsd4.6 machine, perl 5.6.1, gcc 2.x, etc.
> When I try to install mapscript on 3.6.5, it seems to compile and install
> fine, but when I try to "use" it,
> I get an error about an "Unresolved: gdImageGif". If I use the same
> "configure" on an older version
> (my good ol 3.3_012), it runs fine. gd-1.8.4 is installed
http://www.boutell.com/gd/manual1.8.4.html
GD 1.8.4 does not support GIF images. With 3.3 you probably used the GD
version that came with the mapserver package, and not the other one
installed on your system.
hth,
thorsten
