[Mapserver-users] Some improvement might be done for the mapserver's documentation .
Lowell Filak
lfilak at medinaco.org
Wed Jun 4 09:40:34 EDT 2003
Please consider posting all the helpful instructions you have graciously composed to the wiki as it provides an opportunity for everyone to correct/update/add as needed.
Thanks.
Lowell F.
The following message was sent by "pond bear" <pond_bear at hotmail.com> on Tue, 03 Jun 2003 14:57:58 -0500.
> Hi, everybody
> I will attend the first MapServer Users Meeting on St. Paul Campus of the
> University of Minnesota. So we will meet there. See you.
> I have used mapserver for half a year and met a lot difficuties in
> installation and compilation. The documentations about mapserver
> installation on Linux is very misleading. To save you time, here is a list
> of suggestions I will recommend to add into Mapserver help files.
> 1. Mapserver3.7 requires GD2.0.12 or up, which is important but not
> mentioned in " MapServer Unix Compilation and Installation Howto".
> 2. There still is a "Mapplet Howto" while mapplet has been upgraded to jbox.
> Replacing it with "jbox howto" will be more helpful.
> 3. Many people have mentioned the problem "Can't find XXXX.so" after
> installing mapserver, which is due to the library not in the searching path.
> Maybe we can add following in "Mapserver Unix Compilation and Installation
> Howto":
> Add a line in httpd.conf
> "setenv LD_LIBRARY_PATH
> /lib:/usr/lib:/usr/local/lib:/home/oracle/OraHome1/lib"
> 4. "Mapserver PHP/Mapscript Installation Howto" doesn't mention PHP must be
> compiled as a CGI program in Linux, which is the only way we have found to
> get php work with mapserver.
> 5. "MapFile Reference - MapServer 3.7" fails to mention the new features
> such as DATAPATTERN, which is one of the most important new features of 3.7.
> 6. In turtorial and Demo, the input image type is gif which can't be handled
> by mapserver with the default configuration of GD (no gif support). Why not
> make a new version of turtorial and demo using PNG as input image?
> Jing
> University of North Dakota.
> _________________________________________________________________
> MSN 8 with e-mail virus protection service: 2 months FREE*
> http://join.msn.com/?page=features/virus
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
