[Mapserver-users] Using NQuery with OGR MapInfo TAB file
James Perrins
JamesPerrins at esdm.co.uk
Wed Jun 4 14:48:16 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0026_01C32AD2.5A7E6F00
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
After much trial and error I have managed to get the IMGSHPAE command to
work with NQUERY
Previously I was trying to use a MapInfo TAB file - which never seemed
to find any objects (although QUERY mode worked OK). When I translated
the data layer (a layer of points) into a Shape file everything seemed
to work OK.
Is this a known limitation of MapServer - i.e. not being able to do
spatial searches against a MapInfo layer - or is it a bug .
Many Thanks
James
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html>
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 10 (filtered)">
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0cm;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p
{margin-right:0cm;
margin-left:0cm;
font-size:12.0pt;
span.EmailStyle17
{font-family:Arial;
color:windowtext;}
@page Section1
{size:595.3pt 841.9pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-GB link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi,</span></font></p>
font-family:Arial'> </span></font></p>
font-family:Arial'>After much trial and error I have managed to get the =
IMGSHPAE
command to work with NQUERY</span></font></p>
font-family:Arial'>Previously I was trying to use a MapInfo TAB file =
which never seemed to find any objects (although QUERY mode worked =
OK).
When I translated the data layer (a layer of points) into a Shape file =
everything
seemed to work OK.</span></font></p>
font-family:Arial'>Is this a known limitation of MapServer – i.e. =
not
being able to do spatial searches against a MapInfo layer – or is =
it a bug
.</span></font></p>
font-family:Arial'>Many Thanks</span></font></p>
font-family:Arial'>James</span></font></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'> </span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0026_01C32AD2.5A7E6F00--
