[Mapserver-users] perl mapscript 3.6.5 (SOLVED)
mapsurfer
mapsurf at midsouth.rr.com
Wed Jun 4 14:58:33 EDT 2003
Guys, I think I got this solved... When you are installing a private
version
of mapscript, there is a perl Makefile bug that must be manually fixed to
avoid conflict with installed version of libraries on the machine (in
/usr/lib
or /usr/local/lib)
In the perl/mapscript directory,
perl Makefile.PL PREFIX=/usr/home/cto/usr/local
LIB=/usr/home/cto/usr/local/lib
*note: the PREFIX and LIB are needed to create your private version
and where /usr/home/cto is my homedir and my privatedir are is built in
perl MakeMaker will create a canned Makefile template... and if you
inspect the file, you will see:
LDDLFLAGS = -shared -L/usr/local/lib
LDFLAGS = -Wl,-E -L/usr/local/lib
and when change to:
LDDLFLAGS = -shared -L/usr/home/cto/usr/local/lib
LDFLAGS = -Wl,-E -L/usr/home/cto/usr/local/lib
and then
make
make install
problem solved. As far as I can tell, there is no way to override or
otherwise
effect the changes externally since perl Makemaker is responsible for
creating
the Makefile.
Just thought I would pass this info along to anyone else who might be
having problems with a private mapscript installation on a shared machine.
Apparently, its just conflicting with machine libgd.so in /usr/local/lib.
Regards,
Chris Stuber (mapsurfer)
Silicon Mapping Solutions, Inc.
> > On Wed, 2003-06-04 at 00:46, mapsurfer wrote:
> > > My setup is a freebsd4.6 machine, perl 5.6.1, gcc 2.x, etc.
> > > When I try to install mapscript on 3.6.5, it seems to compile and
install
> > > fine, but when I try to "use" it,
> > > I get an error about an "Unresolved: gdImageGif". If I use the same
> > > "configure" on an older version
> > > (my good ol 3.3_012), it runs fine. gd-1.8.4 is installed
