[Mapserver-users] proj.pm build problem
Dana Quinn
dana at nextbus.com
Thu Jun 5 12:51:56 EDT 2003
This is a little bit obscure, but I'll give it a
try. I'm trying to build the proj.pm that Steve
Lime released a while back, and I getting a strange
message that's keeping it from building. I
haven't seen this before, and thought I'd ask about
it here.
(I'm building on a RH 8.0/Perl 5.8 system)
so after I do 'perl Makefile.PL', I do a make and get
this:
$ make
cp proj.pm blib/lib/proj.pm
gcc -c -I/u1/src/ms/proj/include -D_REENTRANT -D_GNU_SOURCE
-fno-strict-aliasing -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
-I/usr/include/gdbm -O2 -march=i386 -mcpu=i686 -DVERSION=\"\"
-DXS_VERSION=\"\" -fpic
"-I/usr/lib/perl5/5.8.0/i386-linux-thread-multi/CORE" proj_wrap.c
proj_wrap.c: In function `_swig_create_magic':
proj_wrap.c:416: warning: assignment from incompatible pointer type
proj_wrap.c:417: warning: assignment from incompatible pointer type
proj_wrap.c: At top level:
proj_wrap.c:750: conflicting types for `boot_proj'
proj_wrap.c:431: previous declaration of `boot_proj'
make: *** [proj_wrap.o] Error 1
Does anyone have any ideas what could be going on here? My
normal troubleshooting technique (pasting the error message into
google), didn't return any matches (sort of amazing). I must
be doing something wrong. I am running a different version
of glibc than another RH8.0 system that this worked on - is
it possible that it could cause a problem?
Any help would be appreciated!
Dana
PS I also re-swig'd, which didn't help, and kind of made things
worse actually.
PPS Wish I could be with you all there at the users conference!
Have fun!
Dana Quinn, dana at nextbus.com
NextBus Information Systems
(510) 420-3117
