[Mapserver-users] rasters with more then 256 colors with gdal
Stephan Holl
sholl at gmx.net
Wed Jun 11 02:05:21 EDT 2003
Dear list,
I have read on the list, that there should be a a mapfile-option to
process rasters with more than 265 colors (e.g. digital elevation
models) directly out of GRASS through gdal.
I tried the processing as Frank suggested on the list eralier, but the
result ist still not comparable to a geotiff.
LAYER
NAME "dem"
GROUP "relief"
TYPE RASTER
STATUS ON
#switch off map at certain min scale (1:1000):
MINSCALE 1000
PROCESSING "SCALE=1066,1840"
DATA "./grassdata/spearfish/PERMANENT/cellhd/elevation.dem"
CLASS
NAME "DEM"
END
END
Also
PROCESSING "SCALE = AUTO" does not solve the problem.
I am using ms 3.7-cvs.
Thanks for any hints.
Stephan Holl
GnuPG Key-ID: 11946A09
