[Mapserver-users] rasters with more then 256 colors with gdal
Ed McNierney
ed at topozone.com
Wed Jun 11 12:21:53 EDT 2003
Stephan -
Can you give us a description (with pictures, if possible) of the result you're trying to produce? It's hard to tell what "comparable to a geotiff" means, since a geotiff can look like anything at all. Thanks!
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Wednesday, June 11, 2003 2:05 AM
To: mapserver-users
Subject: [Mapserver-users] rasters with more then 256 colors with gdal
Dear list,
I have read on the list, that there should be a a mapfile-option to
process rasters with more than 265 colors (e.g. digital elevation
models) directly out of GRASS through gdal.
I tried the processing as Frank suggested on the list eralier, but the
result ist still not comparable to a geotiff.
LAYER
NAME "dem"
GROUP "relief"
TYPE RASTER
STATUS ON
#switch off map at certain min scale (1:1000):
MINSCALE 1000
PROCESSING "SCALE=1066,1840"
DATA "./grassdata/spearfish/PERMANENT/cellhd/elevation.dem"
CLASS
NAME "DEM"
END
END
Also
PROCESSING "SCALE = AUTO" does not solve the problem.
I am using ms 3.7-cvs.
Thanks for any hints.
Stephan Holl
GnuPG Key-ID: 11946A09
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
