[Mapserver-users] rasters with more then 256 colors with gdal
Stephan Holl
sholl at gmx.net
Thu Jun 12 04:08:55 EDT 2003
--=.KYTONg16D4,as/
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
At Wed, 11 Jun 2003 12:21:53 -0400 Ed McNierney wrote:
Hello Ed,
> Can you give us a description (with pictures, if possible) of the
> result you're trying to produce? It's hard to tell what "comparable
> to a geotiff" means, since a geotiff can look like anything at all.
Of course I can send you some pics.
There is a dem-raster-file, which is read as geotiff and renders nicly
through mapserver.
http://www.8ung.at/stephan.holl/tmp/dem_from_tiff.png
but when I try to access the dem from a GRASS-database through gdal it
renders all black as seen here (some contours are above...)
http://www.8ung.at/stephan.holl/tmp/dem_from_grass_through_gdal.png
As I read on the list, there should be the processing-directive to
auto-scale the image.
But when I do
LAYER
PROCESSING "SCALE=AUTO"
END
nothing happens.
I also tried to set in the lowest and the higest point o the dem
PROCESSING "SCALE=1089, 2332"
but same result as above.
What am I doing wrong ?!
Stephan Holl
GnuPG Key-ID: 11946A09
--=.KYTONg16D4,as/
Content-Type: application/pgp-signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.1 (GNU/Linux)
iD8DBQE+6DUbEg9SKhGUagkRAuBZAJ9xYfo01B1Mswu0Sfn8wQ5WBDrgVgCffXcx
+TorSk+KiMky9j2g6hRWY9U=
=eVw2
-----END PGP SIGNATURE-----
--=.KYTONg16D4,as/--
