[Mapserver-users] preventing certain layers from appearing in
thegetCapabilities doc?
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Thu Jun 12 11:26:19 EDT 2003
Yup, that is correct, right now, you can't hide a WMS layer in a given
mapfile, from showing up in GetCapabilities ... Weren't you paying attention
in our workshop debbie ? :)
I haven't checked, but I'd encourage you to file a feature enhancement into
the MapServer bugzilla about this if there isn't one already ... I could use
that feature too :)
Cheers,
J.F.
-----Original Message-----
Sent: Wednesday, June 11, 2003 4:17 PM
To: Debbie Pagurek; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] preventing certain layers from appearing
in thegetCapabilities doc?
If I recall a discussion from the User Meeting correctly, you will need to
use a different Mapfile to do that.
HTH
Lowell F.
The following message was sent by "Debbie Pagurek" <pagurekd at agr.gc.ca> on
Wed, 11 Jun 2003 13:49:05 -0400.
> Hi all,
> I have a mapfile that I am using for an web mapping interface, as well as
doubling as a WMS server. There are layers used in the interface that I
don't want appearing in the getCapabilities document though and I thought I
could prevent them from appearing there by omitting the METADATA tags for
those layers, but that is not the case. Is there a way to select which
layers in a mapfile should appear in a GetCapabilities document?
> Thanks,
> Debbie
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
