[Mapserver-users] preventing certain layers from appearing in thegetCapabilities doc?
Lowell Filak
lfilak at medinaco.org
Wed Jun 11 16:16:45 EDT 2003
If I recall a discussion from the User Meeting correctly, you will need to use a different Mapfile to do that.
HTH
Lowell F.
The following message was sent by "Debbie Pagurek" <pagurekd at agr.gc.ca> on Wed, 11 Jun 2003 13:49:05 -0400.
> Hi all,
> I have a mapfile that I am using for an web mapping interface, as well as doubling as a WMS server. There are layers used in the interface that I don't want appearing in the getCapabilities document though and I thought I could prevent them from appearing there by omitting the METADATA tags for those layers, but that is not the case. Is there a way to select which layers in a mapfile should appear in a GetCapabilities document?
> Thanks,
> Debbie
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
