[Mapserver-users] Mapserver WMS as server to ArcIMS service
Paul Ramsey
pramsey at refractions.net
Fri Jun 13 10:36:19 EDT 2003
Noone answered my question though :)
Isn't there an ESRI-only cascade facility built into recent versions of
ArcIMS which allows ArcIMS to cascade against ArcMap servers? If so,
then there is a chink in the wall through which we can stuff real
cascading :)
Paul
On Friday, June 13, 2003, at 07:04 AM, Ed McNierney wrote:
> No, the only thing the Geography Network does for WMS servers is permit
> them to advertise that they exist. No interoperability with ArcIMS
> servers is provided through the Geography Network.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> Phone: (978) 251-4242 Fax: (978) 251-1396
> ed at topozone.com
> -----Original Message-----
> From: Simpson, Andrew [mailto:Andrew.Simpson at ssc.nasa.gov]
> Sent: Friday, June 13, 2003 8:55 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] Mapserver WMS as server to ArcIMS
> service
> That was the same conclusion we came to; hard to believe there is not a
> mechanism to grab data from a WMS in an ArcIMS service. Isn't the
> geography network WMS? I don't think it even supports cascading
> ArcIMS servers.
> Thanks very much for the responses,
> Drew.
> From: Jean-Francois.Doyon at CCRS.NRCan.gc.ca
> [mailto:Jean-Francois.Doyon at CCRS.NRCan.gc.ca]
> Sent: Thursday, June 12, 2003 4:10 PM
> To: pramsey at refractions.net; ed at topozone.com
> Cc: Andrew.Simpson at ssc.nasa.gov; mapserver-users at lists.gis.umn.edu
> service
> Yup, last I checked that was my understanding as well ... ArcIMS can
> only
> SERVE WMS layers, but cannot ingest them, and therefore cannot cascade
> WMS
> ones.
> I've successfully used the IMS emulator to connect my ArcMap/ArcCatalog
> to a
> MapServer service. If, however you mean you want a given ArcIMS server
> to
> cascade layers provided by the IMS emulator (Thinking it's another
> ArcIMS
> server), I think that's untested so far. I would suspect the emulator
> is
> not evolved or complete enough to support that functionality. If you
> really
> want to you could try to track the requests your IMS emulator gets from
> your
> partner's ArcIMS, read the XML (AXL), and try to figure out where it's
> not
> working. The IMS emulator is Perl, so it's not completely mind-bending
> You should be able to make sense of it all, maybe even make the
> necessary
> improvements if it's worth it to you (And feed them back to Refractions
> My .02$ ... Hope this helps!
> J.F.
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Thursday, June 12, 2003 4:36 PM
> To: Ed McNierney
> Cc: Simpson, Andrew; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Mapserver WMS as server to ArcIMS
> service
> Is this correct? I was of the understanding that the ArcIMS WMS
> connector exposes the ArcIMS data as a WMS server. So if you have set
> up
> the WMS connector on ArcIMS you can use a WMS client to view the ArcIMS
> data. In fact, I have seen it in action in the government here, and
> have
> cascaded a mapserver service onto an ArcIMS server which used the WMS
> connector.
> It is the opposite direction, the ArcIMS server *pulling* data from a
> WMS server, which I whink it impossible... yes?
> P.
> Ed McNierney wrote:
>> Drew -
>> The ArcIMS "OGC Connector" allows an ArcIMS server to connect to WMS
>> layers served by OGC-compliant servers. It's a one-way pipe (we call
> it
>> the "OGC Diode") because it does NOT permit WMS clients to read data
>> from ArcIMS servers. But it sounds like this is something your ArcIMS
>> partners should already be able to do.
>> - Ed
>> Ed McNierney
>> ed at topozone.com
>> (978) 251-4242
>> *From:* Simpson, Andrew [mailto:Andrew.Simpson at ssc.nasa.gov]
>> *Sent:* Thursday, June 12, 2003 3:18 PM
>> *To:* 'mapserver-users at lists.gis.umn.edu'
>> *Subject:* [Mapserver-users] Mapserver WMS as server to ArcIMS
> service
>> Good Afternoon,
>> Has anyone had any success using Mapserver WMS as a source for an
>> ArcIMS service? Would like to share some raster data with an
>> offsite group that only speaks ArcIMS.
>> Used the IMS Emulator to connect with ArcMap and ArcCatalog
> (http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0110/
> msg00298.
> html
>> which worked very well.
>> Sorry for the slightly off topic question.
>> Thanks for any info,
>> Drew.
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Paul Ramsey
