[Mapserver-users] Using CGI mode without temp-images... the images are still being created.
Eduardo Patto Kanegae
eduardo at linkgeo.com.br
Fri Jun 13 22:11:01 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0009_01C33201.0E9381D0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
following some tricks from the mapserver users meeting, I've ported a =
MapServer CGI application to one that does not use temporary image =
files.
the parameters map_web_imagepath and map_web_imageurl were set as an =
empty value ("") inside the mapfile,
and the template file of the application has no mention of these =
parameters too.
I've ported the objects [img], [scalebar], [ref] and [legend] to CGI =
URLs to avoid the use of temp-images.
However, each time I do an interation to the application, 4 image files =
are created at the same path of the application/mapfile.
So, why are these files being created?
thanks
http://www.linkgeo.com.br
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2723.2500" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>following some tricks from the =
mapserver=20
users meeting, I've ported a MapServer CGI application to one that =
does not=20
use temporary image files.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>the parameters map_web_imagepath and=20
map_web_imageurl were set as an empty value ("") inside the=20
mapfile,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>and the template file of the =
application has no=20
mention of these parameters too.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I've ported the objects [img], =
[scalebar], [ref]=20
and [legend] to CGI URLs to avoid the use of temp-images.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>However, each time I do an interation =
to the=20
application, 4 image files are created at the same path of the=20
application/mapfile.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>So, why are these files being =
created?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thanks</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Eduardo Patto Kanegae</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><A=20
href=3D"mailto:eduardo at linkgeo.com.br">eduardo at linkgeo.com.br</A></FONT><=
/DIV>
href=3D"http://www.linkgeo.com.br">http://www.linkgeo.com.br</A></FONT></=
DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV></BODY></HTML>
------=_NextPart_000_0009_01C33201.0E9381D0--
