[Mapserver-users] Using CGI mode without temp-images... the
images are still being created.
Pericles S. Nacionales
nacional at cbs.umn.edu
Sat Jun 14 01:15:39 EDT 2003
Hi Eduardo,
Steve and others probably know more about this than me but I'm wondering
if you can send your template file. Chances are we'll be able to point
out inconsistencies in it.
Cheers!
Perry
On Fri, 2003-06-13 at 21:11, Eduardo Patto Kanegae wrote:
> following some tricks from the mapserver users meeting, I've ported a
> MapServer CGI application to one that does not use temporary image
> files.
> the parameters map_web_imagepath and map_web_imageurl were set as an
> empty value ("") inside the mapfile,
> and the template file of the application has no mention of these
> parameters too.
> I've ported the objects [img], [scalebar], [ref] and [legend] to CGI
> URLs to avoid the use of temp-images.
> However, each time I do an interation to the application, 4 image
> files are created at the same path of the application/mapfile.
> So, why are these files being created?
> thanks
> eduardo at linkgeo.com.br
> http://www.linkgeo.com.br
Pericles S. Nacionales <nacional at biosci.cbs.umn.edu>
University of Minnesota
