[Mapserver-users] Using CGI mode without temp-images...
the images are still being created.
Richard Greenwood
Rich at GreenwoodMap.com
Sat Jun 14 08:32:57 EDT 2003
--=======1A0D204=======
Content-Type: text/plain; x-avg-checked=avg-ok-6D6D738A; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 8bit
At 11:11 PM 6/13/2003 -0300, you wrote:
>following some tricks from the mapserver users meeting, I've ported a
>MapServer CGI application to one that does not use temporary image files.
>the parameters map_web_imagepath and map_web_imageurl were set as an empty
>value ("") inside the mapfile,
>and the template file of the application has no mention of these
>parameters too.
>I've ported the objects [img], [scalebar], [ref] and [legend] to CGI URLs
>to avoid the use of temp-images.
>However, each time I do an interation to the application, 4 image files
>are created at the same path of the application/mapfile.
You need to set STATUS OFF for the whole map file.
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
--=======1A0D204=======--
