[Mapserver-users] Using CGI mode without temp-images... the images are still being created.
Alessandro Galasso
agalasso at gndci.cs.cnr.it
Mon Jun 16 04:50:48 EDT 2003
Hi all... i've tried to do the same as Eduardo.
Setting IMAGEPATH and IMAGEURL to "" and STATUS to OFF doesn't block the
images generation (in query mode, at least).
Alessandro Galasso
----- Original Message -----
From: "Richard Greenwood" <Rich at GreenwoodMap.com>
To: "Eduardo Patto Kanegae" <eduardo at linkgeo.com.br>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Saturday, June 14, 2003 2:32 PM
Subject: Re: [Mapserver-users] Using CGI mode without temp-images... the
> At 11:11 PM 6/13/2003 -0300, you wrote:
> >following some tricks from the mapserver users meeting, I've ported a
> >MapServer CGI application to one that does not use temporary image files.
> >the parameters map_web_imagepath and map_web_imageurl were set as an
empty
> >value ("") inside the mapfile,
> >and the template file of the application has no mention of these
> >parameters too.
> >I've ported the objects [img], [scalebar], [ref] and [legend] to CGI URLs
> >to avoid the use of temp-images.
> >However, each time I do an interation to the application, 4 image files
> >are created at the same path of the application/mapfile.
> You need to set STATUS OFF for the whole map file.
> Rich
> Richard W. Greenwood, PLS
> Greenwood Mapping, Inc.
> (307) 733-0203
> http://www.GreenwoodMap.com
