[Mapserver-users] 16 color tiffs don't display correctly
Twan Kogels
twan at twansoft.com
Mon Jun 16 04:46:48 EDT 2003
Hello,
I've managed to let mapserver display a couple of tiff files at 1:1
resolution so no distortion (from resample or resize) occur. But i have a
problem with displaying tiff files with only 16 colors:
Driver: GTiff/GeoTIFF
Size is 1778, 1185
Coordinate System is `'
Metadata:
TIFFTAG_SOFTWARE=Handmade Software, Inc. Image Alchemy v1.7.7
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 1185.0)
Upper Right ( 1778.0, 0.0)
Lower Right ( 1778.0, 1185.0)
Center ( 889.0, 592.5)
Band 1 Block=1778x8 Type=Byte, ColorInterp=Red
Band 2 Block=1778x8 Type=Byte, ColorInterp=Green
Band 3 Block=1778x8 Type=Byte, ColorInterp=Blue
Band 4 Block=1778x8 Type=Byte, ColorInterp=Alpha
The one with 256 colors displays fine (converted with psp8):
Size is 1778, 1185
Origin = (143979.750000,336020.250000)
Pixel Size = (40.500000,-40.500000)
Metadata:
Corner Coordinates:
Upper Left ( 143979.750, 336020.250)
Lower Left ( 143979.750, 288027.750)
Upper Right ( 215988.750, 336020.250)
Lower Right ( 215988.750, 288027.750)
Center ( 179984.250, 312024.000)
Band 1 Block=1778x8 Type=Byte, ColorInterp=Palette
Color Table (RGB with 256 entries)
0: 0,0,0,255
1: 38,38,38,255
2: 84,84,84,255
3: 127,127,127,255
4: 168,168,168,255
5: 232,232,208,255
6: 255,0,0,255
7: 0,0,255,255
8: 255,255,0,255
9: 255,0,255,255
10: 181,255,84,255
11: 145,181,84,255
12: 160,200,255,255
13: 255,166,89,255
14: 255,110,255,255
15: 255,255,255,255
....(more)...
I've uploaded a example to visualize the error:
<http://spirit.ict-link.nl/~twan/bin/img1.gif>
On this image you see a map seperated by a black line, at the top of the
black line there is a tiff file with 16 colors and at the bottom of the
black line is a tiff file with 256 colors. When creating this example i did
not use the "--without-tiff" option to compile mapserver:
./configure --with-gd --with-tiff --with-jpg --with-png --with-proj
--with-ogr --with-gdal --with-postgis --with-php=/usr/local/src/php-4.3.1/
After searching the mailinglist i found that it maybe a solution to use the
"--without-tiff" option to compile mapserver, so that "gdal" will handle
the reading of the tiff files. So i recompiled mapserver:
./configure --with-gd --without-tiff --with-jpg --with-png --with-proj
The result is better, but there are a couple of minor points. Some colors
seem to disappear when displaying tiffs, a example:
<http://spirit.ict-link.nl/~twan/bin/img2.gif>
As you can see the brown color has disappeared from the tiff file with 16
colors (the top one).
I also noticed a performance decrease from over 100% for small maps to over
400% for big overview maps (overview map at total of 5mb with 23 tiles)
Is there a solution on how to display 16 color tiffs correctly with
mapserver, or should i write a batch file which converts all my maps to 256
colors?
Best regards,
Twan Kogels
