[Mapserver-users] Python mapscript - I fixed it!
Vic Kelson
vic at wittmanhydro.com
Mon Jun 16 10:10:55 EDT 2003
This is a multi-part message in MIME format.
--------------060209030000000605090909
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Hooray!
At Long Last, I have succeeded in making mapscript with python compile,
for mapserver-4.0b. I finally found the error, which is in 'pymodule.i'.
Here it is...
The function _raise_ms_exception() begins with the following code:
static void _raise_ms_exception(void) {
char errbuf[256];
char errmsg[2048]; // room for up to 8 * 256 byte messages
int errcode;
strcpy(errmsg, "");
errorObj *ms_error = msGetErrorObj();
errcode = ms_error->code;
The highlighted line is valid C++, but is not valid C (at least it
wasn't valid in my olden days as a C programmer, or according to
gcc-2.95). I have repaired this by separating the declaration and
assignment:
char errbuf[256];
int errcode;
errorObj *ms_error;
strcpy(errmsg, "");
and now it all compiles successfully on RedHat 7.3 and Debian (woody). I
also had to mangle setup.py to make it work on my system. I'll send my
changes to Sean Gillies, who has helped me out with this mess.
THANKS for the help, folks!
Vic
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
Hooray!<br>
<br>
'pymodule.i'. Here it is...<br>
<br>
The function _raise_ms_exception() begins with the following code:<br>
<br>
<tt>static void _raise_ms_exception(void) {<br>
char errbuf[256];<br>
char errmsg[2048]; // room for up to 8 * 256 byte messages<br>
int errcode;<br>
<br>
<font color="#ff0000"></font> strcpy(errmsg, "");<br>
</tt><tt><font color="#ff0000"> errorObj *ms_error</font></tt><tt><font
color="#ff0000"> = msGetErrorObj();</font><br>
errcode = ms_error->code;<br>
<br>
</tt>The highlighted line is valid C++, but is not valid C (at least it
assignment:<br>
<tt><br>
int errcode;<br>
<font color="#ff0000"><font color="#000000"> errorObj *ms_error;<br>
</font><br>
ms_error = msGetErrorObj();<br>
</tt><br>
I also had to mangle setup.py to make it work on my system. I'll send
my changes to Sean Gillies, who has helped me out with this mess.<br>
<br>
THANKS for the help, folks!<br>
Vic<br>
<br>
<br>
</body>
</html>
--------------060209030000000605090909--
