[Mapserver-users] Python mapscript - I fixed it!
Sean Gillies
sgillies at frii.com
Mon Jun 16 16:03:21 EDT 2003
On Monday, June 16, 2003, at 08:10 AM, Vic Kelson wrote:
> Hooray!
> At Long Last, I have succeeded in making mapscript with python
> compile, for mapserver-4.0b. I finally found the error, which is in
> 'pymodule.i'. Here it is...
> The function _raise_ms_exception() begins with the following code:
> static void _raise_ms_exception(void) {
> char errbuf[256];
> char errmsg[2048]; // room for up to 8 * 256 byte messages
> int errcode;
> strcpy(errmsg, "");
> errorObj *ms_error = msGetErrorObj();
> errcode = ms_error->code;
> The highlighted line is valid C++, but is not valid C (at least it
> wasn't valid in my olden days as a C programmer, or according to
> gcc-2.95). I have repaired this by separating the declaration and
> assignment:
> char errbuf[256];
> int errcode;
> errorObj *ms_error;
> strcpy(errmsg, "");
> and now it all compiles successfully on RedHat 7.3 and Debian (woody).
> I also had to mangle setup.py to make it work on my system. I'll send
> my changes to Sean Gillies, who has helped me out with this mess.
> THANKS for the help, folks!
> Vic
Vic,
Good work, man! I will commit this to CVS. While we're on the subject
of exceptions, are there any other MapServer errors that you'd like to
see mapped into Python exceptions?
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
