[Mapserver-users] mapserver 4.0b projection error
Frank Warmerdam
warmerdam at pobox.com
Wed Jun 18 10:46:29 EDT 2003
Aaron D. Hunt wrote:
> When I run a projection like
> PROJECTION
> "init=epsg:26918" #NAD83 UTM zone 18N
> END
> I get an error "Wed Jun 18 10:24:22 2003 - msProcessProjection():
> Projection library error. no system list, errno: 2"
Aaron,
This generally means that MapServer can't find your epsg coordinate
system file. Try setting the PROJ_LIB environment variable to point
to the directory holding the "epsg" file.
> or
> PROJECTION
> "proj=latlong"
> END
> Wed Jun 18 10:33:53 2003 - msProcessProjection(): Projection library
> error. major axis or radius = 0 or not given
> I have it compiled with proj. Is there something new with 4.0
You need to provide an explicit definiation of the ellipsoid for a valid
latlong coordinate system. Add "ellps=WGS84" for instance giving you:
PROJECTION
"proj=latlong"
"ellps=WGS84"
END
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
