[Mapserver-users] mapserver 4.0b projection error
Aaron D. Hunt
hunt at zedxinc.com
Wed Jun 18 11:21:56 EDT 2003
That worked thanks.
----- Original Message -----
To: "Aaron D. Hunt" <hunt at zedxinc.com>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, June 18, 2003 10:46 AM
Subject: Re: [Mapserver-users] mapserver 4.0b projection error
> Aaron D. Hunt wrote:
> > When I run a projection like
> > PROJECTION
> > "init=epsg:26918" #NAD83 UTM zone 18N
> > END
> > I get an error "Wed Jun 18 10:24:22 2003 - msProcessProjection():
> > Projection library error. no system list, errno: 2"
> Aaron,
> This generally means that MapServer can't find your epsg coordinate
> system file. Try setting the PROJ_LIB environment variable to point
> to the directory holding the "epsg" file.
> > or
> > PROJECTION
> > "proj=latlong"
> > END
> > Wed Jun 18 10:33:53 2003 - msProcessProjection(): Projection library
> > error. major axis or radius = 0 or not given
> > I have it compiled with proj. Is there something new with 4.0
> You need to provide an explicit definiation of the ellipsoid for a valid
> latlong coordinate system. Add "ellps=WGS84" for instance giving you:
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> END
> Good luck,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
