[Mapserver-users] create postgis layer with mapscript gets invalid sql
Twan Kogels
twan at twansoft.com
Thu Jun 19 09:11:42 EDT 2003
Hello,
I'm trying to create a postgis layer with mapscript (php)
$lo=ms_newLayerObj($mymap);
$lo->set("connectiontype", MS_POSTGIS);
$lo->set("connection", "user=postgres dbname=pc");
$lo->set("data", "pc_geom FROM pc6 USING UNIQUE oid USING SRID=-1");
$filter="pc6='$postcode'";
if($filter!="") $lo->setFilter($filter);
$lo->set("name", "postcode_layer");
$lo->set("status", MS_ON);
$lo->set("type", MS_LAYER_POINT);
$lo->setMetaData("DESCRIPTION", "pc6");
$lo->setMetaData("RESULT_FIELDS", "pc6");
$co=ms_newClassObj($lo);
$co->set("name", "mysym");
$temp=$mymap->getSymbolByName('star');
$co->set("symbol", $temp);
$lo->set("classitem", "pc6");
$lo->set("labelitem", "pc6");
$co->label->set("color", $mymap->addColor(0,0,0));
$co->label->set("position", MS_AUTO);
$co->label->set("partials", 0);
$co->label->set("size", MS_TINY);
$co->set("template", "ttt_query.html");
But when i call draw() i get a strange error:
Warning: MapServer Error in prep_DB(): Error executing POSTGIS DECLARE (the
actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
pc6::text,asbinary(force_collection(force_2d()),'NDR'),oid::text from
Dy@XÐ WHERE (pc6=) and ( && setSRID( 'BOX3D(160744 382852,161194
383302)'::BOX3D,-1) )'
Postgresql reports the error 'ERROR: parser: parse error at or near "" at
character 115 '
More Help:
I suspect there's a problem with the query which postgis uses, it contains
a string which postgresql does not like and ofcourse complains about:
Dy@XÐ, this is causing the trouble. Also strange is the "WHERE (pc6=)
and" part, this should be "WHERE (pc6='a zipcode') and".
I have checked the database multiple times, i've created the spatial index
on pc_geom and a index on oid.
I'm using mapserver:
MapServer version 3.6.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
and postgis 0.7.5 with postgresql 7.3.2.
Queries like:
select X(pc_geom) AS geox, Y(pc_geom) AS geoy from pc6 where pc6='5611HL';
just run fine.
Can somebody offer me a helping hand?
Best regards,
Twan Kogels
