[mapserver-users] performance test of ECW tiles
Bart van den Eijnden
bartvde at xs4all.nl
Sun Jun 22 12:35:11 EDT 2003
Hi Thorsten,
yes I did show only a small part of the image for my test.
You're right, with the Microsoft Web Application Stress tool the client
(IE) is on the same machine. My data was on a SCSI drive in the server, so
no network transport.
I used the WMS interface for my test. But by using the WMS interface no
temp files are written, or am I mistaken? I thought everything was streamed
to the client.
Best regards,
Bart
On 22 Jun 2003 20:26:16 +0200, Thorsten Fischer <thfischer at mapmedia.de>
wrote:
> On Thu, 2003-06-19 at 14:37, bartvde at xs4all.nl wrote:
> Hi list,
>> I have done a small performance test with an ECW file of 4,5 Gb. I did
>> my
>> test with the Microsoft Web Application Stress tool for 1 minute. I have
>> done my test in two configurations:
> [ snip ]
> Did you show the whole set every time? Tiles, like indices, do not make
> too much sense if you show all the data at the same time.
> Webmapping application rule number one: Never Show Everything You Got :)
>> I also did not realize the big part DOWNLOAD takes in webmapping
>> performance. The gif files created are around 80 Kb so download will
>> be in
>> the best case around 2 seconds. This is 4 times the time mapserver
>> needs to create the image.
> Plus the latency time for network communication and the time it takes to
> show the resulting image in the browser, especially if the client is on
> the same machine for this test. Plus accessing the file system for temp
> images of course which should not be underestimated, especially if you
> are producing truecolor thingies in 4.0 ...
> There are quite a lot of factors that one needs to keep an eye on. They
> are small, but they do add up.
> That has nothing to do with ecw or image tiling anymore, of course ;)
> hth,
> thorsten
