[Mapserver-users] item query with v3.7/4.0
Randy James
rjames57 at yahoo.com
Thu Jun 19 15:03:27 EDT 2003
Hi
I believe your qstring must be a valid regex expression.
using whatever version of regex you have on your machine.
try /31/
Hope this helps
--- Liz Godwin <godwinl at agr.gc.ca> wrote:
> Hello,
> I'm using Mapserver 3/7/4.0 and attempting to display the
> results of an item query. I'm using the CGI version, and
> sending the request via the URL. The result is that the
> first record in the table is selected and zoomed into,
> not the record queryied for.
> The data is a polygon shapefile. The URL string is:
http://hostname/cgi-bin/mapserv?mode=itemquery&qlayer=mapsheet&qitem=SHEET&qstring=31f&mapext=shapes
> In the map file, the layer is set up like this, however I
> have also triied removing the filter and filteritem
> elements:
> LAYER
> NAME "mapsheet"
> TYPE polygon
> STATUS DEFAULT
> DATA "cliiwms"
> TEMPLATE cli.html
> FILTERITEM "SHEET"
> FILTER "%sheetno%"
> CLASSITEM 'cli_ag'
> CLASS
> NAME mapsheet
> COLOR 220 219 190
> OUTLINECOLOR 156 156 156
> END #CLASS
> PROJECTION
> "init=epsg:42304"
> END
> END #LAYER
> I cannot figure out why this is not working well, plus
> I'd also like clarification on FILTERITEM and FILTER in
> the map file. Are they needed or not needed for queries?
> Thanks for your help,
> Liz Godwin
> Canadian Soil Information System (CanSIS),
> Research Branch, Agriculture and Agri-Food Canada
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
