[Mapserver-users] ArcIMS vs MapServer Functionality - WMS extensions
Till Adams
adams at terrestris.de
Fri Jun 20 02:39:33 EDT 2003
Dear Brock,
there are two extensions to ArcMap which allow to add WMS services:
SICAD
in german:
http://www.sicad.de/pages/produkte/technologie/sicad_extensions/sicad_wms_extension.html
in english:
http://www.sicad.com/pages/products/technology/sicad_extensions/sicad_wms_extension.html
or
con terra
http://www.conterra.de/ >> Information/Service/ >> Downloads >> WMS
Extension (german only)
For both a registration is required, but the software is free. Choose
the one from SICAD, because the conterra tool only is a kind of "demo",
developed to show, that it is POSSIBLE to load WMS services into ArcMap.
You only may load one WMS layer at the same time into ArcMap....
Has anyone an idea about a tool for loading WMS services into ArcView 3.x?
Cheers,
Till
Brock Murch schrieb:
> List Members:
> I am curious whether or not MapServer can supply data directly to a client
> software (not browser) so that the MapServer served data can be applied
> directly to a clients own data.
> For example, with ArcMAP I can query a ArcIMS server and pull down the data to
> my ArcMAP software running locally on my computer. Can this be done with
> MapServer? If not to ArcMAP is it availible for other types of local clients?
> Can MapServer use HDF files? I know that ESRI does not support them.
> Our intended audience uses ESRI products extensively. They will most likely
> want this functionality. We have to make a choice with this in mind. I for
> one advocate the use of open software where ever possbible. This is one
> instance where I may no be able to depending on the response to this query.
> Thanks for any thoughts on the matter.
***** Treffen Sie uns auf der AGIT in Salzburg vom 2. bis 4. Juli 2003,
Stand 35 *****
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
