[Mapserver-users] ArcIMS vs MapServer Functionality
Howard Mark
MHoward at spaceimaging.com
Thu Jun 19 15:54:13 EDT 2003
Brock,
It is easy to write a basic translator to ArcMap for WMS servers. I
have written one in Java that allows connections to WMS servers as if they
were ArcIMS servers.
I've written VB apps that use WMS servers too.
This works great for display/basemaps. If you want to perform spatial
operations, you need to set up MapServer as a WFS (GML) perhaps - then
translate to SDE.
But why would you want to do that?
Mark
-----Original Message-----
From: Brock Murch [mailto:bmurch at seas.marine.usf.edu]
Sent: Thursday, June 19, 2003 1:18 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] ArcIMS vs MapServer Functionality
List Members:
I am curious whether or not MapServer can supply data directly to a client
software (not browser) so that the MapServer served data can be applied
directly to a clients own data.
For example, with ArcMAP I can query a ArcIMS server and pull down the data
to
my ArcMAP software running locally on my computer. Can this be done with
MapServer? If not to ArcMAP is it availible for other types of local
clients?
Can MapServer use HDF files? I know that ESRI does not support them.
Our intended audience uses ESRI products extensively. They will most likely
want this functionality. We have to make a choice with this in mind. I for
one advocate the use of open software where ever possbible. This is one
instance where I may no be able to depending on the response to this query.
Thanks for any thoughts on the matter.
Brock Murch
Managing Director
Institute for Marine Remote Sensing
University of South Florida
140 7th Ave South
St. Petersburg, FL 33701
http://imars.usf.edu/
(727) 553-1186
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
