[Mapserver-users] ArcIMS vs MapServer Functionality
Paul Ramsey
pramsey at refractions.net
Thu Jun 19 15:51:32 EDT 2003
Brock,
This is more a matter of what languages the clients speak than the
languages the server speaks. ArcMap only understands ArcXML, and
therefor is designed to *only* talk with ArcIMS. That was a design
decision by ESRI. Similar things pertain to support for live database
connections (ArcSDE protocol only).
On the bright side, ArcXML is (relatively) easy to emulate. I have
written an emulator (http://postgis.refractions.net/download.php) called
IMSEmu which puts an ArcIMS interface around mapserver, allowing ArcMap
to connect to it directly, as if it were an ArcIMS server. Ed McNierney
and Steve Greenwood will shortly be releasing a PHP script which has the
same functionality and some enhancements they have added.
For less than the cost of an ArcIMS licence, the emulation could be
enhanced to support more of the ArcXML functionality than is currently
supported (queries from ArcMap are currently problematic, due to an
undocumented proprietary format used by ESRI for such queries, but I
have had partial success in reverse engineering it).
So there are alternatives.
BTW, if anyone is interested in funding the addition of support for
ArcExplorer 2.x as a mapserver client (by emulating the AE server
protocol) please drop me a line. I have done the wire sniffing part of
the job, the protocol is not too hard, and it could provide some nifty
capabilities in terms of data download. (ArcExplorer supports a
"download the data" mode, which snaps out a portion of data and zips it
up for local consumption. Given all the format support mapserver has, it
would be a nifty way of exposing obscure data sources to standard
proprietary desktops.)
Paul
Brock Murch wrote:
> List Members:
> I am curious whether or not MapServer can supply data directly to a client
> software (not browser) so that the MapServer served data can be applied
> directly to a clients own data.
> For example, with ArcMAP I can query a ArcIMS server and pull down the data to
> my ArcMAP software running locally on my computer. Can this be done with
> MapServer? If not to ArcMAP is it availible for other types of local clients?
> Can MapServer use HDF files? I know that ESRI does not support them.
> Our intended audience uses ESRI products extensively. They will most likely
> want this functionality. We have to make a choice with this in mind. I for
> one advocate the use of open software where ever possbible. This is one
> instance where I may no be able to depending on the response to this query.
> Thanks for any thoughts on the matter.
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
