[Mapserver-users] Projection library error
Michael Cunningham
mjc1 at soc.soton.ac.uk
Fri Jun 20 05:57:56 EDT 2003
Would be grateful for any help on this one. Have recently installed mapserver,
and it's running fine. However I'm currently working through the on-line
tutorials and have become stuck on projections.
When I run the s3ex4 example, which has the following in the map file:
PROJECTION
"init=epsg:4269"
END
it gives the following error:
msProcessProjection(): Projection library error. no system list, errno: 2
When I run:
% mapserv -v
MapServer version 3.6.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
it shows PROJ.4 is supported.
I've set the PROJ_LIB variable to point at "/usr/local/share/proj" but still
no joy.
I'm running Mandrake Linux9.1, and have the variable set in my .cshrc (running
tcsh).
Any help would be appreciated.
Regards,
Mike
Dr M Cunningham
Challenger Division
Southampton Oceanography Centre
Southampton
SO14 3ZH
Tel: +44 (0)23 80596614
Mobile: +44 (0)79 0153 2191
