[Mapserver-users] Projection library error
Frank Warmerdam
warmerdam at pobox.com
Fri Jun 20 09:17:27 EDT 2003
Michael Cunningham wrote:
> Would be grateful for any help on this one. Have recently installed mapserver,
> and it's running fine. However I'm currently working through the on-line
> tutorials and have become stuck on projections.
> When I run the s3ex4 example, which has the following in the map file:
> PROJECTION
> "init=epsg:4269"
> END
> it gives the following error:
> msProcessProjection(): Projection library error. no system list, errno: 2
> When I run:
> % mapserv -v
> MapServer version 3.6.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> it shows PROJ.4 is supported.
> I've set the PROJ_LIB variable to point at "/usr/local/share/proj" but still
> no joy.
> I'm running Mandrake Linux9.1, and have the variable set in my .cshrc (running
> tcsh).
Mike,
This is presumably your problem. Normally MapServer when run as a cgi-bin
is run with the permissions of the "nobody" account or some other low
permission account. It gets a rather minimal environment and most definately
does not get the environment of your normal user account.
There are various ways of setting environment variables for cgi-bin programs.
You can use the SetEnv directive in the apache configuration file, or create
a "cover script" for mapserv which sets appropriate environment variable.
So many FAQs ... so little time.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
