[Mapserver-users] lambert utm projection
Ed McNierney
ed at topozone.com
Fri Jun 20 10:19:45 EDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C33736.FFB7CA0B
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Sibylle -
=20
It appears that you (and I) are using an older epsg file that has =
several errors in the Austrian projections. I just checked the current =
(version 4.4.7) PROJ epsg file and it has been changed to correct the =
error you found and several other errors (the epsg code for the Austrian =
Lambert, for example, is 31287, not 31297). I compared the 4.4.7 PROJ =
file against the current (version 6.3) EPSG database and all the =
Austrian projections seem OK.
=20
You can download the current version of PROJ from =
http://www.remotesensing.org/proj to get the corrected epsg file.
=20
- Ed
=20
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242=20
-----Original Message-----
From: Sibylle Niederer [mailto:niederer at atlas.gis.univie.ac.at]
Sent: Friday, June 20, 2003 9:31 AM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] lambert utm projection
hi ed,
=20
i got a good hint: lat_0 and lon_0 have to be swaped. now it works.
the problem is that i used EPSG projection and copied the projection =
parameters from the EPSG projection but it is wrong too.
for EPSG 31297 the lat_0 and lon_0 have to be changed.
=20
regards.
sibylle=20
=20
________________________________________________________
=20
INSTITUT fuer GEOGRAPHIE und REGIONALFORSCHUNG
UNIVERSITAET WIEN
Kartographie und Geoinformation
=20
DEPARTMENT of GEOGRAPHY and REGIONAL RESEARCH
UNIVERSITY of VIENNA
Cartography and GIS
=20
Tel: (+43 1) 4277 48658
Fax: (+43 1) 4277 48649
E-Mail: niederer at atlas.gis.univie.ac.at
Snail-Mail: Universitaetstr. 7, A-1010 Wien, AUSTRIA
=20
WWW: http://www.gis.univie.ac.at/karto/
FTP: ftp.gis.univie.ac.at
=20
Atlas of E and SE Europe: http://www.aos.ac.at
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1170" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><SPAN class=3D010401614-20062003><FONT face=3DArial color=3D#0000ff =
size=3D2>Sibylle -</FONT></SPAN></DIV>
size=3D2></FONT></SPAN> </DIV>
size=3D2>It=20
appears that you (and I) are using an older epsg file that has several =
errors in=20
the Austrian projections. I just checked the current (version =
4.4.7) PROJ=20
epsg file and it has been changed to correct the error you found and =
several=20
other errors (the epsg code for the Austrian Lambert, for example, is =
31287, not=20
31297). I compared the 4.4.7 PROJ file against the current =
(version 6.3)=20
EPSG database and all the Austrian projections seem =
OK.</FONT></SPAN></DIV>
size=3D2>You=20
can download the current version of PROJ from <A=20
href=3D"http://www.remotesensing.org/proj">http://www.remotesensing.org/p=
roj</A>=20
to get the corrected epsg file.</FONT></SPAN></DIV>
<DIV><SPAN class=3D010401614-20062003> <FONT =
face=3DArial=20
color=3D#0000ff size=3D2>- Ed</FONT></SPAN></DIV>
<DIV><SPAN class=3D010401614-20062003><FONT =
<DIV><SPAN class=3D010401614-20062003><FONT size=3D2>Ed =
McNierney<BR>President and=20
Chief Mapmaker<BR>TopoZone.com / Maps a la carte, Inc.<BR>73 Princeton =
Street,=20
Suite 305<BR>North Chelmsford, MA =
01863<BR>ed at topozone.com<BR>(978)=20
251-4242 </FONT></DIV></SPAN>
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV class=3DOutlookMessageHeader dir=3Dltr align=3Dleft><FONT =
face=3DTahoma=20
size=3D2>-----Original Message-----<BR><B>From:</B> Sibylle Niederer=20
[mailto:niederer at atlas.gis.univie.ac.at]<BR><B>Sent:</B> Friday, June =
20, 2003=20
9:31 AM<BR><B>To:</B> =
mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> Re:=20
[Mapserver-users] lambert utm projection<BR><BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>hi ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>i got a good hint: lat_0 and lon_0 =
have to be=20
swaped. now it works.</FONT></DIV>
<DIV><FONT size=3D2><FONT face=3DArial>the problem is that i used EPSG =
projection and copied the projection parameters from =
the EPSG=20
projection but it is wrong too.</FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT face=3DArial>for EPSG 31297 the lat_0 =
and lon_0=20
have to be changed.</FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT face=3DArial></FONT></FONT> </DIV>
<DIV><FONT size=3D2><FONT face=3DArial>regards.</FONT></FONT></DIV>
<DIV><FONT size=3D2><FONT face=3DArial>sibylle<FONT=20
color=3D#0000ff> </FONT></FONT></FONT></DIV>
<DIV><FONT face=3DArial=20
size=3D2>________________________________________________________</FONT><=
/DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2> INSTITUT fuer GEOGRAPHIE =
und=20
REGIONALFORSCHUNG<BR> UNIVERSITAET WIEN<BR> =20
Kartographie und Geoinformation</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2> DEPARTMENT of GEOGRAPHY =
and REGIONAL=20
RESEARCH<BR> UNIVERSITY of VIENNA<BR> =
Cartography and=20
GIS</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2> =20
Tel: (+43 1) 4277=20
48658<BR> Fax: =
(+43 1)=20
4277 48649<BR> E-Mail: <A=20
href=3D"mailto:niederer at atlas.gis.univie.ac.at">niederer at atlas.gis.univie=
.ac.at</A><BR> =20
Snail-Mail: Universitaetstr. 7, A-1010 Wien, AUSTRIA</FONT></DIV>
<DIV> </DIV>
WWW: <A=20
href=3D"http://www.gis.univie.ac.at/karto/">http://www.gis.univie.ac.at/k=
arto/</A><BR> =20
FTP: <A=20
href=3D"ftp://ftp.gis.univie.ac.at">ftp.gis.univie.ac.at</A></FONT></DIV>=
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2> Atlas of E and SE =
Europe: <A=20
href=3D"http://www.aos.ac.at">http://www.aos.ac.at</A><BR> _________=
_______________________________________________<BR></FONT></DIV></BLOCKQU=
OTE></BODY></HTML>
------_=_NextPart_001_01C33736.FFB7CA0B--
