[Mapserver-users] Log user actions
Steve Lime
steve.lime at dnr.state.mn.us
Fri Jun 20 14:45:21 EDT 2003
You use the logfile like this:
WEB
LOG 'mapserver.log'
END
You should create an empty logfile of the same name with the right
permissions (needs to be writable by the web user, like the temporary
directory). If the filename is relative then it's relative to the
location of the mapfile.
The format is a comma delimited line consisting of:
timestamp
process id
remote address (ip)
map name
mode
extent
mouse click (if available)
requested layers
status (either an error message or "normal execution")
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Giri Palanisamy <palanisamyg at ornl.gov> 06/20/03 01:17PM >>>
Thanks Steve,
Is there a documentation or sample code that I can refer?
Giri
At 01:05 PM 6/20/2003 -0500, you wrote:
>You could use MapScript of course. There is also a LOGFILE option
(for
>the WEB object I believe) that tells the MapServer CGI to create a
log
>for you. It gives you the information you'd want.
>Steve
> >>> Giri Palanisamy <palanisamyg at ornl.gov> 06/20/03 08:15AM >>>
>Hi,
>I need to log some information (date, IP address etc..)in to the data
>base,
>when ever an user performs a query. I tried using server side include
>(.shml) a servlet that performs this function, but I think the
>mapserver is
>not supporting the .shtml.
>Is there a way to log information? I am using Mapserver 3.6.3 on
>windows
>2000 server
>Thanks
>Giri
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
