[mapserver-users] cannot draw Oracle layer
Bart van den Eijnden
bartvde at xs4all.nl
Fri Jun 20 16:02:13 EDT 2003
Hi Frank,
I added CPL_DEBUG as an environment variable (value = ON). I restarted my
Apache webserver. But still nothing is written to the Apache error file (I
assume stderr will turn up there or not?).
Are there any more debug options to turn on for the mapserver code itself?
And does the error message refer to a problem with getting the data, or can
it get the data but is it not possible for mapserver to render it?
Thanks,
Bart
On Fri, 20 Jun 2003 15:50:48 -0400, Frank Warmerdam <warmerdam at pobox.com>
wrote:
> Bart van den Eijnden wrote:
>> Hi list,
>> I have problem with rendering an Oracle layer. The layer is correct
>> because it can be rendered by other webmapping software.
>> I get an error, regardless of whether I use the built-in Oracle
>> connector or through OGR.
>> The error is:
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'kwadranten'.
>> How can I get more debug info, because I have debug on. But I do not see
>> anything in the Apache logs nor at the client.
> Bart,
> Sorry for not doing anything on your several questions this week. I have
> been intending to spend an hour or two committed to reviewing Oracle OGR
> issues but haven't gotten to it yet.
> I would suggest you try setting the CPL_DEBUG environment variable to ON
> to get substantial quantities of debugging information from OGR (written
> to stderr).
> The error message is produced msDrawMap() if msDrawLayer() returns a
> failure
> code. Not very helpful, but at least it indicates which layer failed to
> render.
> Best regards,
