[mapserver-users] cannot draw Oracle layer
Frank Warmerdam
warmerdam at pobox.com
Fri Jun 20 15:50:48 EDT 2003
Bart van den Eijnden wrote:
> Hi list,
> I have problem with rendering an Oracle layer. The layer is correct
> because it can be rendered by other webmapping software.
> I get an error, regardless of whether I use the built-in Oracle
> connector or through OGR.
> The error is:
> msDrawMap(): Image handling error. Failed to draw layer named 'kwadranten'.
> How can I get more debug info, because I have debug on. But I do not see
> anything in the Apache logs nor at the client.
Bart,
Sorry for not doing anything on your several questions this week. I have
been intending to spend an hour or two committed to reviewing Oracle OGR
issues but haven't gotten to it yet.
I would suggest you try setting the CPL_DEBUG environment variable to ON
to get substantial quantities of debugging information from OGR (written
to stderr).
The error message is produced msDrawMap() if msDrawLayer() returns a failure
code. Not very helpful, but at least it indicates which layer failed to render.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
