[Mapserver-users] Newbie Question -- San Francisco map isn't happening
    Gregory S. Williamson
    gsw at globexplorer.com
    Fri Jun 20 14:51:38 PDT 2003
Thanks for the tip ... I must have something amiss though as I commented out the "proj=..." stuff and used:
PROJECTION
 "init=epsg:26910"
END
And when I run it I get:
msProcessProjection(): Projection library error. no system list, errno: 2
Perhaps this version doesn't do projections ? Or I don't have the right files in the right places ? I did dowload a proj446_win32_bin.zip file and put the proj.dll into the WINDOWS/SYSTEM directory and set a couple of DOS environment variables. Perhaps I don't have the epsg file where it should be ?
Thanks for your time,
Greg W.
-----Original Message-----
From:	Swaminathan, Gayathri [mailto:gayathri at ou.edu]
Sent:	Fri 6/20/2003 2:12 PM
To:	Gregory S. Williamson
Cc:
Subject:	RE: [Mapserver-users] Newbie Question -- San Francisco map isn't happening
Pardon me on my previous reply,dint notice the UTM projection in Arcview for
coords.
Seems like the Projection is the problem.
Try changing that to "init=epsg:26910"
also, why is that "north" in that projection?
The EXTENT coordinates should be right if you got them from Arcview.
Thanks,
Gayathri
More information about the MapServer-users
