[Mapserver-users] Newbie Question
Swaminathan, Gayathri
gayathri at ou.edu
Fri Jun 20 17:57:15 EDT 2003
Aah! The famous
"msProcessProjection(): Projection library error. no system list, errno: 2"
error.
Query on the same on Google or mapserver list.
Ed McNierney and Frank have helped some users with that in the past.
You should be able to get tones of info on this in the list.
Thanks,
Gayathri
-----Original Message-----
From: Gregory S. Williamson [mailto:gsw at globexplorer.com]
Sent: Friday, June 20, 2003 2:52 PM
To: Swaminathan, Gayathri
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Newbie Question -- San Francisco map
isn't happening
Thanks for the tip ... I must have something amiss though as I commented out
the "proj=..." stuff and used:
PROJECTION
"init=epsg:26910"
END
And when I run it I get:
Perhaps this version doesn't do projections ? Or I don't have the right
files in the right places ? I did dowload a proj446_win32_bin.zip file and
put the proj.dll into the WINDOWS/SYSTEM directory and set a couple of DOS
environment variables. Perhaps I don't have the epsg file where it should be
Thanks for your time,
Greg W.
