[Mapserver-users] Newbie Question
Ed McNierney
ed at topozone.com
Fri Jun 20 18:24:46 EDT 2003
And they're still willing to help now <g>.
The "epsg" is really a file name, and you're going to need a file named
c:\proj\nad\epsg to make things work. If you unpack the entire PROJ
distribution you downloaded, you should find this file.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242 Fax: (978) 251-1396
ed at topozone.com
-----Original Message-----
From: Swaminathan, Gayathri [mailto:gayathri at ou.edu]
Sent: Friday, June 20, 2003 5:57 PM
To: 'Gregory S. Williamson'
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Newbie Question
Aah! The famous
"msProcessProjection(): Projection library error. no system list, errno:
2"
error.
Query on the same on Google or mapserver list.
Ed McNierney and Frank have helped some users with that in the past.
You should be able to get tones of info on this in the list.
Thanks,
Gayathri
From: Gregory S. Williamson [mailto:gsw at globexplorer.com]
Sent: Friday, June 20, 2003 2:52 PM
To: Swaminathan, Gayathri
Subject: RE: [Mapserver-users] Newbie Question -- San Francisco map
isn't happening
Thanks for the tip ... I must have something amiss though as I commented
out
the "proj=..." stuff and used:
PROJECTION
"init=epsg:26910"
END
And when I run it I get:
2
Perhaps this version doesn't do projections ? Or I don't have the right
files in the right places ? I did dowload a proj446_win32_bin.zip file
and
put the proj.dll into the WINDOWS/SYSTEM directory and set a couple of
DOS
environment variables. Perhaps I don't have the epsg file where it
should be
Thanks for your time,
Greg W.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
