[Mapserver-users] Newbie Question
Gregory S. Williamson
gsw at globexplorer.com
Fri Jun 20 18:43:30 EDT 2003
Gayathri,
Thanks muchly for the answer ... A search of the system archives seems to have yielded a result of putting the epsg file in C:\PROJ\NAD (where the precompiled binary looks for it I guess).
I now have:
NAME SSF
STATUS ON
SIZE 600 600
EXTENT 542724.08 4173551.37 557476.48 4187315.33
UNITS METERS
SHAPEPATH "DATA"
IMAGECOLOR 255 255 255
PROJECTION
"init=epsg:26910"
END
No error messages ! (progress!)
And still no map ... a legend showing the yellow lines as streets, and a scale bar, no errors in the log file, but still no image.
Drat.
I will continue to troll the archives, but all ideas are welcome.
Greg W.
-----Original Message-----
From: Swaminathan, Gayathri [mailto:gayathri at ou.edu]
Sent: Fri 6/20/2003 2:57 PM
To: Gregory S. Williamson
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] Newbie Question
Aah! The famous
"msProcessProjection(): Projection library error. no system list, errno: 2"
error.
Query on the same on Google or mapserver list.
Ed McNierney and Frank have helped some users with that in the past.
You should be able to get tones of info on this in the list.
Thanks,
Gayathri
From: Gregory S. Williamson [mailto:gsw at globexplorer.com]
Sent: Friday, June 20, 2003 2:52 PM
To: Swaminathan, Gayathri
Subject: RE: [Mapserver-users] Newbie Question -- San Francisco map
isn't happening
Thanks for the tip ... I must have something amiss though as I commented out
the "proj=..." stuff and used:
PROJECTION
"init=epsg:26910"
END
And when I run it I get:
Perhaps this version doesn't do projections ? Or I don't have the right
files in the right places ? I did dowload a proj446_win32_bin.zip file and
put the proj.dll into the WINDOWS/SYSTEM directory and set a couple of DOS
environment variables. Perhaps I don't have the epsg file where it should be
Thanks for your time,
Greg W.
