[Mapserver-users] mapserv doesn't work
=?gb2312?q?Chen=20Fu?=
novalet at yahoo.com.cn
Sun Jun 22 02:11:01 EDT 2003
Hi!
Will it be possible that somebody share the compiled
mapserv with me? If the compile use static lib, it can
also used in my linux box, right?
Thanks
--- Vincent Schut <schut at sarvision.com> µÄÕýÎÄ£º>
Chen,
> it is very strange that from the commandline mapserv
> works, but not from your
> browser. Your server should simply start mapserv and
> stream the output to
> your browser... Are you sure that you have the right
> mapserv executable in
> the right cgi-bin directory (sorry for the obvious
> question, don't mean to
> offend... :-)) ? But you won't be the first one to
> copy your new mapserv in
> an old cgi-bin dir that is not used anymore... (did
> it once myself).
> Try using not only localhost/cgi-bin/mapserv, but
> add the values you added as
> querystring at the commandline
> (http:/localhost/cgi-bin/mapserv
> map=/../../map.map&mode=map
> What do you get then?
> BTW you don't need php to use mapserver, I was wrong
> in assuming that you used
> php... Mapserver as cgi is just as powerfull as the
> php/mapscript version, I
> think. At least powerfull enough for this debugging.
> Good luck!
> Vincent.
> On Friday 20 June 2003 16:05, Chen Fu wrote:
> > Vincent:
> > Thank you for your reponse!
> > My mapserv works in "Query...", it print out a lot
> of
> > ascii as you said. I think it is the data of the
> > generated image.
> > Then what should i do? Should i config something
> like
> > php? My project doesn't use php up to now. But it
> will
> > be accepted if mapserv has to work with php lib.
> > Chen,
> > > The error you get is a very generic error
> generated
> > > by php I think. To find
> > > out more about what goes wrong, you should at
> least
> > > run mapserver from the
> > > command prompt, and prefereable thourgh a
> debugger.
> > > To run it from the command prompt, type (in the
> dir
> > > where the mapserv
> > > executable is):
> > > ./mapserv
"QUERY_STRING=map=/var/mapserver/mapfiles/province2.map&mode=map"
> > > (of course fill in your own mapfile/path and
> > > eventual other parameters. I
> > > think you need to specify at least map and mode.
> > > This example prints the
> > > image data to stdout, so you will see your png
> or
> > > gif or whatever scrolling
> > > as ascii on you terminal :-)
> > > But probably you will see an error message
> instead
> > > of image data.
> > > If it is still very generic, like a segmentation
> > > fault, you should use a
> > > debugger.
> > > To run mapserv from the debugger, do the
> following:
> > > make sure you have gdb (the gnu debugger) and
> type:
> > > gdb mapserv
> > > run
> > > and after the error, type:
> > > backtrace
> > > This will show you in which function mapserv (or
> a
> > > library) segfaulted.
> > > Maybe than you will know what to do. Otherwise,
> send
> > > your experiences and the
> > > mapserv and debugger output to this list and
> I'm
> > > sure you will get more
> > > help.
> > > Cheers,
> > > Vincent Schut.
> > > On Friday 20 June 2003 09:12, Chen Fu wrote:
> > > > Till£º
> > > > My linux box is base on redhat8. the make
> > > generate
> > > > some warning but no error. the mapserv is
> 375445
> > > > bytes. I think it is much smaller than the one
> i
> > > used
> > > > in win2k. But i config it with gd lib only.
> > > > if i type "./mapserv" it will show
> > > > This script can only be used to decode form
> > > results
> > > > and
> > > > should be initiated as a CGI process via a
> httpd
> > > > server.
> > > > Is it mean the file is a validate executable?
> > > shp2img
> > > > generated in the same procession work very
> nice.
> > > > I search the archive for that message before i
> > > post it
> > > > here. But most i found is related to php or
> some
> > > other
> > > > thing. Because i am a newbie in compiling
> > > mapserver in
> > > > linux, so i select the cleanest way, use only
> gd
> > > lib.
> > > > But still get into trouble, sigh...
> > > > --- Till Adams <adams at terrestris.de>
> µÄÕýÎÄ£º>
> > > Dear
> > > > Cheng,
> > > > > "premature end of script" is an error which
> > > occurs,
> > > > > when the compile
> > > > > process was broken up: so while compiling,
> the
> > > > > "mapserv" was written but
> > > > > not finished. Which linux system do you use?
> Did
> > > you
> > > > > get an error
> > > > > message when compiling? Try the mailing list
> > > archive
> > > > > searching for
> > > > > contributions fitting to your error message.
> > > > > Good luck,
> > > > > Till
> > > > > Chen Fu schrieb:
> > > > > > Hi!
> > > > > > This is my first time to compile mapserver
> in
> > > > > linux.
> > > > > > But I use mapserver in win2k for a long
> time.
> > > > > > First download gd-2.0.15, make and install
> it.
> > > > > > Then i download mapserver4.0b, make it and
> > > copy
> > > > > > mapserv to cgi-bin.
=== message truncated ===
Remote Scensing Satellite Ground Station
Chinese Academy of Science
_________________________________________________________
Do You Yahoo!?
ÍøÁµµÄÚ¹ÊÍ£ºÕæÇ黹ÊÇ·Å×Ý£¿
http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/netlove
