[Mapserver-users] mapserv doesn't work
=?gb2312?q?Chen=20Fu?=
novalet at yahoo.com.cn
Mon Jun 23 22:12:16 EDT 2003
Pericles:
Thank you! I really find the root of my failure. I
check the log of apache, there is something wrong with
libgd. Here is the content of error_log. I don't know
why mapserver try to find libgd.so.2 when i run in cgi
mode. But it work fine when it is used in command
line. What's up?
.0.0.1] Premature end of script headers: mapserv
[Fri Jun 20 10:19:36 2003] [error] [client 127.0.0.1]
/var/www/cgi-bin/mapserv: error while loading shared
libraries: libgd.so.2: cannot open shared object file:
No such file or directory
[Fri Jun 20 10:19:47 2003] [error] [client 127.0.0.1]
attempt to invoke directory as script:
/var/www/cgi-bin/
[Fri Jun 20 10:19:53 2003] [error] [client 127.0.0.1]
[Fri Jun 20 15:21:00 2003] [error] [client 127.0.0.1]
[Fri Jun 20 22:00:45 2003] [error] [client 127.0.0.1]
[Fri Jun 20 22:00:48 2003] [error] [client 127.0.0.1]
[Fri Jun 20 22:00:51 2003] [error] [client 127.0.0.1]
[Fri Jun 20 22:19:31 2003] [error] [client 127.0.0.1]
[Fri Jun 20 22:20:00 2003] [error] [client 127.0.0.1]
[Sat Jun 21 11:14:52 2003] [error] [client 127.0.0.1]
[Sat Jun 21 11:17:01 2003] [error] [client 127.0.0.1]
[Sat Jun 21 11:17:25 2003] [error] [client 127.0.0.1]
script not found or unable to stat:
[Sat Jun 21 11:23:47 2003] [error] [client 127.0.0.1]
/var/www/cgi-bin/mapserv map=
[Sat Jun 21 11:23:57 2003] [error] [client 127.0.0.1]
[Sat Jun 21 11:31:01 2003] [error] [client 127.0.0.1]
[Sat Jun 21 11:35:35 2003] [error] [client 127.0.0.1]
[Sat Jun 21 11:37:41 2003] [error] [client 127.0.0.1]
[Sun Jun 22 04:02:03 2003] [notice] SIGHUP received.
Attempting to restart
--- "Pericles S. Nacionales" <nacional at cbs.umn.edu>
µÄÕýÎÄ£º> Chen,
> Have you checked your web server's error log to see
> if there's any
> relevant messages related to mapserv? I can compile
> MapServer for you
> but I don't know if that will solve your problems.
> -Perry
> On Sun, 2003-06-22 at 01:11, Chen Fu wrote:
> > Hi!
> > Will it be possible that somebody share the
> compiled
> > mapserv with me? If the compile use static lib, it
> can
> > also used in my linux box, right?
> > Thanks
> > --- Vincent Schut <schut at sarvision.com>
> çæ£æï¼>
> > Chen,
> > > it is very strange that from the commandline
> mapserv
> > > works, but not from your
> > > browser. Your server should simply start mapserv
> and
> > > stream the output to
> > > your browser... Are you sure that you have the
> right
> > > mapserv executable in
> > > the right cgi-bin directory (sorry for the
> obvious
> > > question, don't mean to
> > > offend... :-)) ? But you won't be the first one
> to
> > > copy your new mapserv in
> > > an old cgi-bin dir that is not used anymore...
> (did
> > > it once myself).
> > > Try using not only localhost/cgi-bin/mapserv,
> but
> > > add the values you added as
> > > querystring at the commandline
> > > (http:/localhost/cgi-bin/mapserv
> > > map=/../../map.map&mode=map
> > > What do you get then?
> > > BTW you don't need php to use mapserver, I was
> wrong
> > > in assuming that you used
> > > php... Mapserver as cgi is just as powerfull as
> the
> > > php/mapscript version, I
> > > think. At least powerfull enough for this
> debugging.
> > > Good luck!
> > > Vincent.
> > > On Friday 20 June 2003 16:05, Chen Fu wrote:
> > > > Vincent:
> > > > Thank you for your reponse!
> > > > My mapserv works in "Query...", it print out a
> lot
> > > of
> > > > ascii as you said. I think it is the data of
> the
> > > > generated image.
> > > > Then what should i do? Should i config
> something
> > > like
> > > > php? My project doesn't use php up to now. But
> it
> > > will
> > > > be accepted if mapserv has to work with php
> lib.
> çæ£æï¼>
> > > > Chen,
> > > > > The error you get is a very generic error
> > > generated
> > > > > by php I think. To find
> > > > > out more about what goes wrong, you should
> at
> > > least
> > > > > run mapserver from the
> > > > > command prompt, and prefereable thourgh a
> > > debugger.
> > > > > To run it from the command prompt, type (in
> the
> > > dir
> > > > > where the mapserv
> > > > > executable is):
> > > > > ./mapserv
"QUERY_STRING=map=/var/mapserver/mapfiles/province2.map&mode=map"
> > > > > (of course fill in your own mapfile/path and
> > > > > eventual other parameters. I
> > > > > think you need to specify at least map and
> mode.
> > > > > This example prints the
> > > > > image data to stdout, so you will see your
> png
> > > or
> > > > > gif or whatever scrolling
> > > > > as ascii on you terminal :-)
> > > > > But probably you will see an error message
> > > instead
> > > > > of image data.
> > > > > If it is still very generic, like a
> segmentation
> > > > > fault, you should use a
> > > > > debugger.
> > > > > To run mapserv from the debugger, do the
> > > following:
> > > > > make sure you have gdb (the gnu debugger)
> and
> > > type:
> > > > > gdb mapserv
> > > > > run
> > > > > and after the error, type:
> > > > > backtrace
> > > > > This will show you in which function mapserv
> (or
> > > a
> > > > > library) segfaulted.
> > > > > Maybe than you will know what to do.
> Otherwise,
> > > send
> > > > > your experiences and the
> > > > > mapserv and debugger output to this list
> and
> > > I'm
> > > > > sure you will get more
> > > > > help.
> > > > > Cheers,
> > > > > Vincent Schut.
> > > > > On Friday 20 June 2003 09:12, Chen Fu wrote:
> > > > > > Tillï¼
> > > > > > My linux box is base on redhat8. the
> make
> > > > > generate
> > > > > > some warning but no error. the mapserv is
> > > 375445
> > > > > > bytes. I think it is much smaller than the
> one
> > > i
> > > > > used
> > > > > > in win2k. But i config it with gd lib
> only.
> > > > > > if i type "./mapserv" it will show
> > > > > > This script can only be used to decode
> form
> > > > > results
> > > > > > and
> > > > > > should be initiated as a CGI process via a
> > > httpd
> > > > > > server.
> > > > > > Is it mean the file is a validate
> executable?
> > > > > shp2img
> > > > > > generated in the same procession work very
> > > nice.
> > > > > > I search the archive for that message
> before i
> > > > > post it
> > > > > > here. But most i found is related to php
> or
> > > some
> > > > > other
> > > > > > thing. Because i am a newbie in compiling
=== message truncated ===
Remote Scensing Satellite Ground Station
Chinese Academy of Science
_________________________________________________________
Do You Yahoo!?
ÍøÁµµÄÚ¹ÊÍ£ºÕæÇ黹ÊÇ·Å×Ý£¿
http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/netlove
