[Mapserver-users] Dynamic points
Eric Bridger
eric at gomoos.org
Mon Jun 23 07:17:18 EDT 2003
With mapserver (a web mapping application) the map is created from
scratch with each web request. Unless your layers have a STATUS of
DEFAULT they need to be turned ON each time. So your dynamic points
will be lost/cleared automatically or re-filled with your new query
results.
Eric
On Mon, 2003-06-23 at 13:51, Adam Zornes wrote:
> All,
> I am developing a Mapserver application which will, in
> addition to other things, be able to dynamically create a query layer
> based on user defined searches on a database.
> I understand how to add points to a dummy layer to display
> the database search results. What I can't figure out is how to remove
> these points when a user wants to do a new search. Is it possible to
> remove an entire layer? Is it possible to clear all the features in a
> layer?
> Thanks in advance for any help.
> Cheers,
> Adam Zornes
> Athenic Systems
