[Mapserver-users] Dynamic points
    Adam Zornes
    zornes at athenic.com
    Mon Jun 23 06:51:40 PDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C3398E.92A85A33
Content-Type: text/plain;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
All,
=20
            I am developing a Mapserver application which will, in
addition to other things, be able to dynamically create a query layer
based on user defined searches on a database. =20
            I understand how to add points to a dummy layer to display
the database search results. What I can't figure out is how to remove
these points when a user wants to do a new search.  Is it possible to
remove an entire layer?  Is it possible to clear all the features in a
layer? =20
            Thanks in advance for any help.
=20
Cheers,
Adam Zornes
Athenic Systems
Content-Type: text/html;
	charset="us-ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3396D.2AF78970">
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]-->
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0in;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
span.EmailStyle17
	{mso-style-type:personal-compose;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
span.SpellE
	{mso-style-name:"";
	mso-spl-e:yes;}
@page Section1
	{size:8.5in 11.0in;
	margin:1.0in 1.25in 1.0in 1.25in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0in 5.4pt 0in 5.4pt;
	mso-para-margin:0in;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>All,<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'><span =
style=3D'mso-tab-count:1'>        =
;    </span>I
am developing a <span class=3DSpellE>Mapserver</span> application which =
will, in
addition to other things, be able to dynamically create a query layer =
based on
user defined searches on a database. <span
style=3D'mso-spacerun:yes'> </span><o:p></o:p></span></font></p>
;    </span>I
understand how to add points to a dummy layer to display the database =
search results.
What I can’t figure out is how to remove these points when a user =
wants
to do a new search.<span style=3D'mso-spacerun:yes'>  </span>Is it =
possible
to remove an entire layer?<span style=3D'mso-spacerun:yes'>  =
</span>Is it
possible to clear all the features in a layer?<span
;    </span>Thanks
in advance for any help.<o:p></o:p></span></font></p>
font-family:Arial'>Cheers,<o:p></o:p></span></font></p>
font-family:Arial'>Adam Zornes<o:p></o:p></span></font></p>
font-family:Arial'>Athenic Systems<o:p></o:p></span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C3398E.92A85A33--
More information about the MapServer-users
