[Mapserver-users] modify layer attributes in runtime and change map output
Michael Härtel
mhaerte1 at gwdg.de
Tue Jun 24 03:08:09 EDT 2003
Hello all,
for some reason i'm unable to modify the attributes of layers in runtime
to achieve a different map display.
The map always matches the attribut definitions in the map file, no
matter which attributes i change.
My code is:
---- snip! ----
$obj_map = ms_newMapObj($mapfile_path.$map_file);
$layer=$obj_map->getlayerbyName('boundaries');
$str_expression="('[country_name]' = 'germany')";
$obj_class->setExpression($str_expression);
$obj_class=$querylayer->getclass(0);
$obj_color=$obj_class->label->outlinecolor;
$obj_color->setrgb(0,0,255);
$layer->set(status, MS_ON);
---- snip! ----
$image=$obj_map->draw();
$image_url=$image->saveWebImage(MS_PNG,1,1,0);
I guess there are some basic errors in my code.
Can somebody tell me how to tell MapServer that the modified layer
should be drawn instead of the layer defined in the mapfile?
Thanks a lot,
Michael
