[Mapserver-users] Compiling Mapserver/configure options
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Tue Jun 24 10:53:47 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C33A60.6AA5AD60
Content-Type: text/plain;
charset="iso-8859-1"
Benjamin,
That is indeed confusing, and I'm not entirely sure of the underlying reason
for seeing it in there twice.
But, as a rule of thumb, I would give configure as much information as
possible ... Better too much than not enough.
A good thing to do if you're learning how to use the whole "autoconf" world
is to run a simple "./configure" with NO options.
Read the output, as it is fairly detailed, figure out what you feel is
missing that you need, and then add the options. It's a
repetitive/iterative process, but it's the best way to learn this, and
you'll find it much easier next time you have to compile something.
Normally, "configure" will detect the system's jpeg and png libraries
automagically anyways, so you don't really have to specify them on the
command line. I've never had the situation where it doesn't since I use
Linux, and pretty much all Linux distributions come with those libs
installed ... If it doesn't however, just to be safe, I'd install them.
Are there any developpers out there that could tell us why the JPEG and PNG
libraries are looked for outside of GD support ? (I'm thinking it might be a
historical leftover also ...)
Hope this helps,
J.F.
-----Original Message-----
Sent: Monday, June 23, 2003 6:49 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Compiling Mapserver/configure options
Hi list,
I'm quite new to Linux and compiling software from source, so bare with me.
When it comes to compiling Mapserver I have some questions regarding the
./configure options.
There are some components with seem to be duplicated in different parts of
the compile process. For example I can compile jpeg support separately into
gd, gdal and mapserver.
Am I right in saying that if I compile jpeg into gdal I can have jpeg as an
input data source? If I compile jpeg into gd I can output jpeg images? If I
have compiled jpeg into gd I don't need to compile it into mapserver
directly with the --with-jpeg (as long as I use --with-gd) as it will use
gd's code to do jpeg manipulation? Similar with png?
Thanks,
Benjamin Wragg
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1">
<TITLE>Message</TITLE>
<META content="MSHTML 6.00.2722.900" name=GENERATOR></HEAD>
<BODY>
<DIV><SPAN class=513244614-24062003><FONT face=Arial color=#0000ff
size=2>Benjamin,</FONT></SPAN></DIV>
size=2></FONT></SPAN> </DIV>
<DIV><SPAN class=513244614-24062003><FONT face=Arial color=#0000ff size=2>That
is indeed confusing, and I'm not entirely sure of the underlying reason for
seeing it in there twice.</FONT></SPAN></DIV>
<DIV><SPAN class=513244614-24062003><FONT face=Arial color=#0000ff size=2>But,
as a rule of thumb, I would give configure as much information as possible ...
Better too much than not enough.</FONT></SPAN></DIV>
<DIV><SPAN class=513244614-24062003><FONT face=Arial color=#0000ff size=2>A good
thing to do if you're learning how to use the whole "autoconf" world is to run a
simple "./configure" with NO options.</FONT></SPAN></DIV>
<DIV><SPAN class=513244614-24062003><FONT face=Arial color=#0000ff size=2>Read
the output, as it is fairly detailed, figure out what you feel is missing that
you need, and then add the options. It's a repetitive/iterative process,
but it's the best way to learn this, and you'll find it much easier next time
you have to compile something.</FONT></SPAN></DIV>
size=2>Normally, "configure" will detect the system's jpeg and png libraries
automagically anyways, so you don't really have to specify them on the command
line. I've never had the situation where it doesn't since I use Linux, and
pretty much all Linux distributions come with those libs installed ... If it
doesn't however, just to be safe, I'd install them.</FONT></SPAN></DIV>
<DIV><SPAN class=513244614-24062003><FONT face=Arial color=#0000ff size=2>Are
historical leftover also ...)</FONT></SPAN></DIV>
<DIV><SPAN class=513244614-24062003><FONT face=Arial color=#0000ff size=2>Hope
this helps,</FONT></SPAN></DIV>
size=2>J.F.</FONT></SPAN></DIV>
<BLOCKQUOTE dir=ltr style="MARGIN-RIGHT: 0px">
<DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma
size=2>-----Original Message-----<BR><B>From:</B> Benjamin Wragg
[mailto:bwragg at tpg.com.au]<BR><B>Sent:</B> Monday, June 23, 2003 6:49
PM<BR><B>To:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B>
[Mapserver-users] Compiling Mapserver/configure options<BR><BR></FONT></DIV>
<DIV><SPAN class=765273722-23062003><FONT face=Arial size=2>Hi
list,</FONT></SPAN></DIV>
<DIV><SPAN class=765273722-23062003><FONT face=Arial size=2>I'm quite new to
Linux and compiling software from source, so bare with me. When it comes
to compiling Mapserver I have some questions regarding the ./configure
options. </FONT></SPAN></DIV>
<DIV><SPAN class=765273722-23062003></SPAN><SPAN
class=765273722-23062003><FONT face=Arial size=2>There are some components
with seem to be duplicated in different parts of the compile process. For
example I can compile jpeg support separately into gd, gdal and mapserver.
<DIV><SPAN class=765273722-23062003><FONT face=Arial size=2>Am I right in
saying that if I compile jpeg into gdal I can have jpeg as an input data
source? </FONT></SPAN><SPAN class=765273722-23062003><FONT face=Arial
size=2>If I compile jpeg into gd I can output jpeg images? If I have compiled
jpeg into gd I don't need to compile it into mapserver directly with the
--with-jpeg (as long as I use --with-gd) as it will use gd's code to do jpeg
manipulation? </FONT></SPAN><SPAN class=765273722-23062003><FONT face=Arial
size=2>Similar with png?</FONT></SPAN></DIV>
size=2>Thanks,</FONT></SPAN></DIV>
<DIV><SPAN class=765273722-23062003><FONT face=Arial size=2>Benjamin
Wragg</FONT></SPAN></DIV></BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C33A60.6AA5AD60--
