[Mapserver-users] Compiling Mapserver/configure options
Benjamin Wragg
bwragg at tpg.com.au
Mon Jun 23 18:48:58 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0001_01C33A29.43C4FFC0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi list,
I'm quite new to Linux and compiling software from source, so bare with
me. When it comes to compiling Mapserver I have some questions regarding
the ./configure options.
There are some components with seem to be duplicated in different parts
of the compile process. For example I can compile jpeg support
separately into gd, gdal and mapserver.
Am I right in saying that if I compile jpeg into gdal I can have jpeg as
an input data source? If I compile jpeg into gd I can output jpeg
images? If I have compiled jpeg into gd I don't need to compile it into
mapserver directly with the --with-jpeg (as long as I use --with-gd) as
it will use gd's code to do jpeg manipulation? Similar with png?
Thanks,
Benjamin Wragg
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<TITLE>Message</TITLE>
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR></HEAD>
<BODY>
<DIV><SPAN class=3D765273722-23062003><FONT face=3DArial size=3D2>Hi=20
list,</FONT></SPAN></DIV>
<DIV><SPAN class=3D765273722-23062003><FONT face=3DArial=20
size=3D2></FONT></SPAN> </DIV>
<DIV><SPAN class=3D765273722-23062003><FONT face=3DArial size=3D2>I'm =
quite new to=20
Linux and compiling software from source, so bare with me. When it =
comes to=20
compiling Mapserver I have some questions regarding the ./configure =
options.=20
<DIV><SPAN class=3D765273722-23062003></SPAN><SPAN =
class=3D765273722-23062003><FONT=20
face=3DArial size=3D2>There are some components with seem to be =
duplicated in=20
different parts of the compile process. For example I can compile jpeg =
support=20
separately into gd, gdal and mapserver. </FONT></SPAN></DIV>
<DIV><SPAN class=3D765273722-23062003><FONT face=3DArial size=3D2>Am I =
right in saying=20
that if I compile jpeg into gdal I can have jpeg as an input data =
source?=20
</FONT></SPAN><SPAN class=3D765273722-23062003><FONT face=3DArial =
size=3D2>If I=20
compile jpeg into gd I can output jpeg images? If I have compiled jpeg =
into gd I=20
don't need to compile it into mapserver directly with the --with-jpeg =
(as long=20
as I use --with-gd) as it will use gd's code to do jpeg manipulation?=20
size=3D2>Similar=20
with png?</FONT></SPAN></DIV>
size=3D2>Thanks,</FONT></SPAN></DIV>
<DIV><SPAN class=3D765273722-23062003><FONT face=3DArial =
size=3D2>Benjamin=20
Wragg</FONT></SPAN></DIV></BODY></HTML>
------=_NextPart_000_0001_01C33A29.43C4FFC0--
